Old 06-18-2013, 07:03 PM   #1
Southern Shaker
Has anyone Rhinolined ?
Has anybody rhino lined the inside of there blazer ? Floors ,etc. Any pics ? ill be doing this very soon wanted to see if anyone had ?
Southern Shaker is offline   Reply With Quote
Old 06-19-2013, 07:16 AM   #2
Re: Has anyone Rhinolined ?
Mines carpeted. But,if I went the rough and tough route I's stay away from Rhino Liner.Line-X is a far superior (and attractive) product
Old 06-19-2013, 08:59 AM   #3
Southern Shaker
well lined in general I guess I should say haha
Old 06-19-2013, 01:11 PM   #4
70-K5
I have lined the complete tub on an 86 K5, I used a DIY kit from Herculiner. Cost a hundred bucks and came out great. It is all in the prep, the better you prep the surface the better it will turn out and the longer it will last.
If you have somebody spray Line-X or similar product you will pay way more... I mean waaaay more. DIY is fine for a tub.
Heard good things about the RustOleum and DupliColor, little softer texture than the Herculiner.
70-K5 is offline   Reply With Quote
Old 06-19-2013, 01:23 PM   #5
vegadesign
vegadesign's Avatar
i used it on the inside of my 84 k5 and it works *****en
not a everyday use kinda material but it does the job.
mine wore out after about 5 years but all you have to do is go back and get another gallon and your set
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 06-19-2013, 01:36 PM   #6
Southern Shaker
they sell the herculiner diy kit for 89.99 down at the hardware store I been thinkin bout it
Old 06-20-2013, 12:55 PM   #7
67cheby
67cheby
67cheby's Avatar
I will be doing mine inside and underneath, I did Cloud 9 also, with Line X then painted over it on the underneath side, sure cuts out a ton of road noise !
67cheby is offline   Reply With Quote
Old 06-20-2013, 10:35 PM   #8
Blazin77
Blazin77's Avatar
This is what I'm using on my K5, comes in many colors as well.
http://www.monstaliner.com/
Dusty
In the words of Huey Lewis.. "It's Hip to be Square".
1977 Blazer
............________
.........../_____ |__\__
..........|_(O)______(O)]
Blazin77 is offline   Reply With Quote
Old 06-20-2013, 10:44 PM   #9
mgchevyparts
mgchevyparts's Avatar
I'll be doing the rear section of my 75 Jimmy, the front seat area will be carpeted. I've seen others and they look very good.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 06-21-2013, 07:44 AM   #10
I use that Dupli-Color spray on a lot of things. It's a real light coating compared to the roll-on and commercial professional stuff like Line-X. I should have said,if you are paying to have it done and want the best then it's Line-X all the way. There is no do it yourself coating that compares. It's worth every penny if a serious tough "and" attractive coating is what you want. I've had them mask and spray things like powder coated ladder racks,so the outer and under areas you see were the metallic powder coat and the upper & inner wear surfaces were color-match with a clean crisp line between the two.
I spray my shocks,fender wells,and stuff like that with the Dupli-Color. I've even sprayed on a '67 glovebox door to match the instrument panel texture. I have another set of ladder racks I sprayed about quite few years ago and it's held up pretty well. It did wear off the top edges where equipment was slid across it repeatedly. That was why I Line-Xed the other set. Even powder coat wears off.
Old 06-21-2013, 10:25 AM   #11
blazer2007
Is there any smell in the cab expecially when it gets hot out ?
blazer2007 is offline   Reply With Quote
Old 06-21-2013, 11:02 AM   #12
cyclefreak207
cyclefreak207's Avatar
I rhinolined the floor in my nova. It didn't reduce much heat or noise... and when my feet were wet or dirty and then the floor got dirty it seems like i could never get it to look as fresh and black as it did when I first sprayed it.
If I did it again, I'd probably try line-x... everyone else seems to like it better.
86 Short Bed Build
I don't always downshift when I want to change lanes... But when I do, I make sure it's next to a prius so they know I'm hurting the environment!
cyclefreak207 is offline   Reply With Quote
Old 06-21-2013, 11:46 AM   #13
70-K5
Initially yes, but after a week or so when it fully cures nope, no smell at all.
If you do try a DIY kit beware of the fumes, when it says work in a well ventilated area they are not kidding!
and because of the texture you may have a hard time getting all the dust and dirt out of the crevices unless you use a pressure washer, however if you built your rig with the ability to use a pressure washer on the inside then you probably don't care about a bit of dirt in the cracks...
