Old 06-28-2003, 11:40 AM   #1
69 Short Fleet
Question Need Help ASAP "Sound Deadener Kit"
Hello to All: I need help ASAP please, I'm about to install my sound deadener kit (the white foam / ashphalt kind, aka EVA) directly on the floorpan (white foam first, and then the asphalt sheet next on top of the white foam) but my question is, should I use an areosol type of glue (and what brand works best 3M or ???) to hold the white foam in place (especially around the trans. hump) and then glue the same areas between the white foam and asphalt sheet also? Thanks very much, Doug
69 Short Fleet is offline   Reply With Quote
Old 06-28-2003, 02:10 PM   #2
Piston
Piston's Avatar
I just threw mine on the floor and put the carpet in. Once its all installed its going NOWHERE. Be careful of any aerosol cans, the propelent will cause the styrofoam pad to melt.
Piston is offline   Reply With Quote
Old 06-28-2003, 02:49 PM   #3
69 Short Fleet
Thanks for your help Piston, I layed the sound deadener in a couple of days ago (just kinda placed it as best I could) and after I wrote this thread I went out to have another look at it and it fits way better now after the hot weather we had. I guess the "EVA" kinda form fitted itself, thanks again, Doug
