Yet ANOTHER backspace question
Can't believe I can't get this into my head yet. Search results came up inconclusive.
20x8.5" rear wheel. Recommended backspace? Same as front: 5"? [Not bagged, 6" drop in rear] |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Yet ANOTHER backspace question
No.
Most 10's require a 5.5" BS. So that equals a 4" BS on a 8.5" wheel mounted on the back. (remember the front track width is wider than the rear track width). Break out a tape and verify this.
Sooo...if I went 8.5s all the way around, I'd have to get them in two different offsets (front and rear)?
Most wheels are cast so you won't have a choice of BS, cast wheels usually come one way, so which wheel are you looking at, and what is it's back space?
#5 | |
Or run spacers on the rear. That's why most people run 8's and 10's or 7's and 8's. It help hides the wider front track width of these trucks.
Gotcha. So I could go 5" BS all the way around and run a 1" spacer on the rear, correct?
I really don't know why I find this such a hard concept to grasp...I found a set of 20x8.5 w/ 4.5" of BS. Will this work for me. 4.5" will pull the wheel 1.2" to the *inside* versus a wheel w/ 5" of B.S., correct? So worst case, I could run a 1/2" spacer up front. |
#8 | |
BS is measure on the backside of the wheel. Higher the "backspace number",... the more it will tuck under the fender. 5" backspace wheel will tuck 1/2" more than a 4.5" backspace wheel. (as long as the wheels are the same width).
So is 4.5 a no-go on a 5/7 drop then?
I my opinion you need a 5.25" bs on a 8.5" wheel up front.
#11 | |
Slugish
![]() Join Date: Jan 2005
got 9.5 rims on back with 4 in B.S.bout as much as can work ---> close but ok got 8 in rims on front with 5.5 b s -> could have gone with 5 in or possibly 4.5 Im running 17 in rims w/ a 5.5 - 7 drop . hope this helps > think low life is right on the mark |
.....High Positive Offset____________________________High Negative Offset (aka "reversed") Last edited by wraprail; 06-20-2013 at 06:31 AM. |
| Bookmarks |
