Old 06-19-2013, 09:18 AM   #1
rs74
rs74's Avatar
Is there a write up on the Jeep steering shaft conversion.
Just came across someone mentioning it and trying to find out more about it. Exactly why is it done and if there is a link to it then please post. I assume this can be done to 2wd and 4wd trucks both. Does it just give a more responsive feel and take out the slop?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 06-19-2013, 09:24 AM   #2
wraprail
wraprail's Avatar
Re: Is there a write up on the Jeep steering shaft conversion.
idk about jeep. I used an Astro van shaft. Has u-joints on both ends and required only slight modification.
wraprail is offline   Reply With Quote
Old 06-19-2013, 12:00 PM   #3
Billy81
Billy81's Avatar
http://67-72chevytrucks.com/vboard/s...rokee+steering
Billy81 is offline   Reply With Quote
Old 06-19-2013, 02:39 PM   #4
rs74
rs74's Avatar
Originally Posted by Billy81 View Post
Hey Billy, Thanks!. Just had a pup fly out from Medford a few months ago. Got one from Selma.
Okay so what does this do exactly. From what I gather so far it is to give you better feel in the wheel and maybe take out some of the play? Is that right?
Roy
1987 R10 shortie
Old 06-19-2013, 03:07 PM   #5
1774btcrew
1774btcrew's Avatar
It does take out the slop and make it more responsive. Current GM trucks are set up this way.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-19-2013, 03:10 PM   #6
1774btcrew
1774btcrew's Avatar
To be clear, anyone thinking about doing this upgrade you need a 79 and newer steering column as they have the double D shaft on the engine compartment side.
