06-19-2013, 09:59 AM | #1 |
???steering wheel???
cant figure out how to remove horn ring,without damaging it .can you help?
06-19-2013, 11:17 AM | #2 |
It's Better With Nitro
Re: ???steering wheel???
There should be three button head screws (they have an odd shape slot, but you can use a small flathead screw driver to remove them) that hold the horn contact spacer under the center cap. Once those are removed, the horn ring should come right off.
06-19-2013, 11:22 AM | #3 |
Use a flat blade screw driver to pop the center cap first then there are three phillips screw heads on the inside.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
06-19-2013, 11:34 AM | #4 |
Be careful with the screwdriver pressure on the wheel just under the center portion. The plastic will be brittle from age and might break. If you are careful you should be OK.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
06-20-2013, 01:01 AM | #5 |
thx fellas got it
