Old 06-19-2013, 06:50 PM   #1
dabarber
Engine Identification
I bought a 1969 GMC K25 with a V8 but I know it's not stock. Can someone tell me how to identify it?
Numbers stamped on the right front of the block:
F1205TL
T8Z512150
dabarber is offline   Reply With Quote
Old 06-19-2013, 07:44 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Engine Identification
The "TL" suffix code come up with a 1957 265 2bbl.
Got any pics? Also get the number off the back of the engine on the flange the bellhousing mates to. Cast in numbers will be on the drivers side.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-19-2013, 11:27 PM   #3
dabarber
I can post some pictures later, but the engine is so close to the firewall, that I can't see that casting number on the back.
Old 06-20-2013, 08:00 AM   #4
Bigdav160
Bigdav160's Avatar
Perhaps just shoot a pic of the pad. Those numbers are not making sense to me.
1966 was the last year for a Flint V8 to use the "F". They changed to a "V". No more two letter suffix codes after '68.
The VIN wasn't used on all engines until 1968 and the "8Z512150" suggest it was used at the Fremont California plant which built El Caminos but again in '68 it should have been a "V1205TL"
Is this a small block?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-22-2013, 01:50 PM   #5
dabarber
Here are some pictures, hopefully someone can tell me what I have.
F1205TL
T8Z512150
Old 06-22-2013, 02:37 PM   #6
bruceman1968
bruceman1968's Avatar
The suffix code has a K after the TL. So with code TLK and the 8 in the parcial VIN you have a 1978 truck motor. It's a 400cid, 175hp, RPO code LF-4, 4bbl Rochester carb, from a 10 or 20 series, 4wd truck. Originaly.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 06-23-2013, 05:01 PM   #7
dabarber
Thank you, Bruceman, the guy I bought it from said it was a 400, but I didn't know for sure. By the way, that's a big dog in your picture!
