Fabricate till you "puke"
Ls engine hardware? (or 2)
I have the heads off the 5.3, for Lap & seals. I know that the tty head bolts need to be replaced, but what about the rocker bolts? Also, do you replace valley cover bolts, valve cover bolts,ect? New to the LS side, any help is appreiciated
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Truck and auto performance nut
Re: Ls engine hardware? (or 2)
Definitely the head bolts need to be replaced. I think those others are OK....if you pull the crank pulley replace that bolt too tho.
Or.....just buy an ARP motor set and replace them as you go.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
As far as I know only the head bolts are torque to yield. The rest of the bolts go ahead and reuse.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Thanks guys, the lobes look good, as do the rollers....budget this trip ,maybe 3 mm overbore the next time... & a little stroke?.Time to get my feet wet a bit. Many thanks, Longhorn
