06-19-2013, 08:25 PM | #1 |
BBC Power Steering Pump
Did a search and couldn't find much.
Does anyone have a part number or supplier for a 1972 BBC Power Steering Pump with the remote reservoir? Thanks |
06-19-2013, 09:59 PM | #2 |
Re: BBC Power Steering Pump
You can get them at Autozone. I don't know if you have Autozone in Canada.
06-20-2013, 04:27 AM | #3 |
Is it part number 7010?
Posted via Mobile Device |
06-21-2013, 12:33 AM | #4 |
I talked to a guy at the Pomona Swap Meet a couple weeks ago that specializes in BBC bolt on accessories. Mostly Pulleys and brackets but he also does steering gears and pumps. His contact info on his card is...
E-bay: gotpulley E-mail: bigblockjim454@cox.net phone H (480)981-3096 Phone C (602)751-0454 Might be worth a phone call if he has what you need. |
06-21-2013, 05:47 PM | #5 |
good info
06-21-2013, 05:53 PM | #6 |
Wide n'Low
Rock auto lists one w/res, LARES 2129 w/ Reservoir; Reman
I just replaced mine this week, using one without a res - CARDONE SELECT Part # 96140 it took me all of 10 minutes to take the res off the old one and using new seals (included) install it on the new one. its really pretty simple.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
05-13-2016, 07:53 PM | #7 |
Looks like i'm revisiting my own thread!
Twisted, how was it to separate the housing from the pump? looks like the one i ended up buying sat for a few years and it leaks like crazy, so i thought i'd replace the pump to housing o-ring. |
05-13-2016, 08:39 PM | #8 |
motor exploder
A few taps with a soft faced mallet and it will come right off.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-13-2016, 09:03 PM | #9 |
Just wanna make sure you mean to tap the housing where the lip rolls over the face of the pump and have it slide back? Undo all the fittings on the back first I assume.
