Old 06-20-2013, 09:10 AM   #1
CruzByU
51 Chevy truck brake questions.
I'm working on my 51 Chevy 3100. I plan on keeping the 235 6-banger, and mating up a mid 80's T-5 Borg Warner to it. I'm also swapping the rear end out for a 4x4 unit from an S-10. I want to upgrade to power brakes with dual master cyl. I'm quessing the new power boosters run off of vacuum, and will my 235 have enough to operate it? I looked at the power brake boosters already on the web and some says they can only be used with automatic transmissions, why would that be, pedal configuration under the floor? Any thoughts fellers?
CruzByU is offline   Reply With Quote
Old 06-20-2013, 09:42 AM   #2
dan42
dan42's Avatar
Re: 51 Chevy truck brake questions.
Pictures of the rig are required. Too many guys that relate visually.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 06-20-2013, 10:33 AM   #3
mknittle
mknittle's Avatar
"Pedal configuration under the floor"? That's what I would say. There aresome guys that mounted the booster/master cylinder farther back. As far as behind the cab. that would buy some room for the clutch linkage.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-20-2013, 10:43 AM   #4
Trekster
Trekster's Avatar
Your 235 will have plenty of vacuum for the power booster.
A lot of the under floor brake brackets are built for an automatic because the bracket itself is built in such a way that the clutch pedal mount is eliminated. I guess that the after market guys think most people will put an automatic in.
Trekster is offline   Reply With Quote
Old 06-20-2013, 11:56 AM   #5
CruzByU
Thanks for the replies. I quess I get to do a little fab work, cause I shifting me some damn gears!
Old 06-20-2013, 01:54 PM   #6
lazypineapple
lazypineapple's Avatar
Check with CPP
http://www.classicperform.com/Instru...rakeClutch.htm
lazypineapple is offline   Reply With Quote
Old 06-20-2013, 02:13 PM   #7
nvrdone
Who says you can't have power brakes with a manual trans ? I have a 327 / m21 with power drum brakes front and rear.
I used a bracket from no limit - pn -pbc 47 with a 79 mustang booster and m/c. I did have to use a 10# check valve in the front. The stock clutch and brake pedals work good along with the stock manual clutch linkage. The only clearance issue was the cross member under the rear of the trans. I had to use a tube mount instead of the stock square mount.
nvrdone is offline   Reply With Quote
Old 06-20-2013, 03:29 PM   #8
Trekster
Trekster's Avatar
I built my own bracket and put a booster under the floor. I made it so it bolted to the original bracket that held the old master cylinder.
Old 06-20-2013, 04:34 PM   #9
CruzByU
Good info guys, I'm gonna check out the CCP website, looks like it could be the way to go. Thanks.
Old 06-20-2013, 04:54 PM   #10
solidaxel
solidaxel's Avatar
Might want to take a look at ECI, engineered components inc
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
