06-28-2003, 06:47 PM | #1 |
Nothing clever
turn signal repair
anyone know if I need to take off the wheel to get to the parts?? I bought all of the parts today, just have no diagram, and I think the wheel is a pain in the azz to take off.
06-28-2003, 07:26 PM | #2 |
Weapons Of Construction
Yes, you need to remove the wheel to service the turn signal switch. You will also probably end up pulling apart some of the dash to reach the connectors.
Removing the wheel isn't usually that bad. Remove the horn button cap. Loosen the nut with a socket (remove the safety clip if there is one). Leave the nut on with most of the threads engaged, like about 1/8" back from original position. Grasp the steering wheel at 3 and 9 o'clock. Plant your feet firmly on the floor and pull on the steering wheel while rocking it (pull away from the dash on the left, then right, repeat). It may come back easy or it may pop when it breaks loose and you will appreciate the fact that you left the nut there or your head would be stuck in the back window. After it breaks loose, remove the nut and the wheel. If it won't break loose easily, go to your local auto parts store and see if you can rent or borrow a steering wheel puller. These trucks are easy since the key is in the dash. The newer vehicles have a lock ring that's a PITA to remove unless you have the right tools or a lot of patience and a helper. Good Luck!
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
06-28-2003, 08:57 PM | #3 |
Inline 69
heres a little tip,,,,,,,,dis-connect your battery "first",,,,its not part of the process ,but you wont have to listen to the horn blow everytime you bump the ground wire while working on your signal assembly......
06-28-2003, 09:48 PM | #4 |
I removed my steering wheel to check on sloppy actuating turn signal lever....This caused intermittent operation of the turn signal... Found that the small screws that attached the turn signal lever were partially stripped from the plastic body.... Also, the body of the mechanism was cracked so that the cam would not move far enough to atuate the signals properly..... Using J-B weld; some small clamps and small wire around the portion of the mechanism holding the signal lever. After the J-B weld
had set up; checked the operation and was just fine...Did this over 10 years ago; and not a problem.....Jim
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
06-28-2003, 10:50 PM | #5 | |
20' Daredevil (Ret)
06-29-2003, 12:37 AM | #6 |
its all about the +6 inches
I have personally never been able to pull a G.M. steering wheel by hand, and if has been there for 10,20...30 years, it may not come off at all...even with the puller.
Don't let anyone tell you to beat the shaft with a hammer and brass drift, the poor desigh of the column along with the age will destroy the bearings in there. (ask me how I know) Get the puller...rent or buy. It is a nice tool to have on hand, some models double as a harmonic balancer puller, and in a pinch, i have used one to remove the lower gear of a timing chain set off the crank snout. (inginuity kicks ass) |
06-29-2003, 02:59 PM | #7 |
Nothing clever
signals
I was unsuccesful trying to pull the wheel off with my hand. I went to the Kragen near me and they loan tools for free! got it all apart and fixed it all up nice, just cant seem to figure out how to put it back togehter. go tit all together except for the very top.
I cant seem to put the horn assembly back together right so that the horn doesn't blow non stop. I think it has something to do with the spring assembly and the thin metal plate along with the three screw horn cap holder. Can anyone outline how these are supposed to go back together? |
06-29-2003, 04:33 PM | #8 |
Inline 69
ive got 3 different diagrams,,,,,#tilt, #2 column shift,and if you have a floor mounted shifter,theres 4 pieces omitted,,,,,,,,which one do you need
06-29-2003, 10:09 PM | #9 |
Nothing clever
column
column shift 3 speed/ non tilt
06-30-2003, 12:15 AM | #10 |
Inline 69
columnshift
hope it helps,,,,,,,
06-30-2003, 01:05 AM | #11 |
Nothing clever
thanks but...
it appears to not be detailed enough. ALTHOUGH BELIEVE ME I APPRECIATE THE EFFORT.
