Old 06-20-2013, 04:14 PM   #1
67 chevelle
67 chevelle's Avatar
New heartbeat 68
Got the ly6 in the hole , tranys next , thats why its tilting
67 chevelle is offline   Reply With Quote
Old 06-20-2013, 04:16 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: New heartbeat 68
it's gonna be great!!!
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 07-23-2013, 03:21 PM   #3
67 chevelle
First start today fired up after 3 or 4 turns of the key , now I have to get a drivers side battery tray and fab a bracket for the ecu and relays , easy stuff
2 issues at start up , one major header leak , had to tightn the bolts , and the mechanical fan does not seem to want to turn , anyone know if these fans are temp controled , its white plastic bladesb , with some kind of clutch , from a 08 silverado
Old 07-23-2013, 06:14 PM   #4
ItWillBeSlow
ItWillBeSlow's Avatar
is that medium blue?
ItWillBeSlow is offline   Reply With Quote
Old 07-23-2013, 06:37 PM   #5
Mister-B
Sure looks like light blue to me, which is the same color as my '69. I believe they only did this color through '69
Mister-B is offline   Reply With Quote
Old 07-23-2013, 07:46 PM   #6
Daaaanz67
By fan not turning do you mean that it's free wheeling spinning but not the same speed as the motor? If so its because the bi metallic spring on the front of the fan clutch has not sensed enough heat to lock up the fan. Usually on cold start ups the fan will lock for a slight moment you should hear a semi loud roar then free wheel. Have you had it up to normal operating temp?
Daaaanz67 is offline   Reply With Quote
Old 07-23-2013, 08:22 PM   #7
67 chevelle
not to temp yet , in the past i have dealt with flex fans , and electric , the heat sensitive clutch is new to me , thanks for en-lighting me
Old 07-23-2013, 08:55 PM   #8
67 chevelle
i think its light blue also the glove box sticker is gone
Old 07-23-2013, 09:03 PM   #9
slow-1
slow-1's Avatar
Nice work!
My next truck will be that color.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 07-23-2013, 09:22 PM   #10
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Looks like she is sitting in there at a pretty extreme angle! lol
I think you are going to have to build a cradle with tires to support the rear of the trans.
prostreetC-10 is offline   Reply With Quote
Old 07-23-2013, 09:31 PM   #11
67 chevelle
new pic tomarow
Old 07-24-2013, 09:38 AM   #12
67 chevelle
Middle picture shows how I cut and welded the #1 header tube to work with the cpp mounts ,
Now I just need to fab a drivers side battery tray and bracket for my ecu and relays , seems to run strong , will know for sure with road test coming shortly , the front end is still on the lift , it sits a couple inches lower , got a 3/5 cpp drop kit , will post a pic at ride height with hood on , after I paint the underside and and hindges and install , this board and its members have been of GREAT HELP to me , as a matter of fact without 67c10rustbuckets help , I would still be messing with my steering , thanks guys , switched from ram assist to a power unit from a 79
Old 07-24-2013, 09:41 AM   #13
prostreetC-10
My Carbon Footprint
When old meets new! That's sweet.
