What is this??
Hey guys, I feel a bit dumb asking this, but on my '69 there is a small (1"x2") silver box beside the fuse panel, mounted to the firewall under the dash. A 3-wire plug comes from the fuse panel and connects to it. What is this component, and what is it's purpose?
The reason I ask is I'm trying to track down a battery drain issue (1 amp drain with ignition off), and as soon as I connect the battery, I can hear this box "click". Is it a relay? If I leave the battery connected the box becomes quite hot. Sorry I don't have a picture of it handy, otherwise I'd include it. I'm sure you'll know what I'm referring to. Thanks in advance!
![]() Matt. 16:26 '08 Sierra Reg Cab, shortbox - daily driver '69 C10 LWB, 250, 3OTT - summer driver '98 STi Type-R (JDM) <SOLD> '97 WRX STi (JDM) <SOLD> |
![]() Join Date: Mar 2007
Re: What is this??
Yes I think what you are describing is a horn relay. Sounds like it might be for the horn? Hook up the battery and honk your horn. Then unplug it and try to honk it again if it doesn't work it's for the horn.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
Moderator
![]() Join Date: May 2007
Re: What is this??
Horn relay
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: What is this??
Ahhh that makes sense, I haven't installed my horns yet, and the column isn't properly put together either. I bet the horn contact is closed for some reason and causing the drain. I'll check it out. Thanks fellas
Re: What is this??
I had the same issue in my truck with no horn installed, replaced the relay anyway and fixed the issue.
