Old 06-20-2013, 07:42 PM   #1
kdml
Gas in Fuel Tank Wiring
I noticed fuel was leaking from the wiring for the dual fuel tanks. After closer inspection I noticed the fuel is running inside the insulation of the wiring and leaking out anywhere there is a break in the wiring for connections. I searched for where the fuel was getting on the wiring with no luck. I pulled the plug on the fuel tank selector and fuel poured out. I assume this means I need a new selector switch and mine has an internal leak. Anyone had this happen to them? Fuel and electrical positioned over the dual exhaust is a recipe for disaster.
Doug
kdml is offline   Reply With Quote
Old 06-20-2013, 09:19 PM   #2
pontgta
pontgta's Avatar
Re: Gas in Fuel Tank Wiring
Yeah , common actually to leak after years of use, so just replace, and you should be good for a few years..... I got mine from do Autozone the have lifetime warranty
pontgta is offline   Reply With Quote
