06-20-2013, 11:39 PM | #1 |
Thinking of turning a 67-72 bed into a trailer
Is it wrong to turn a bed into a trailer? Want it to match my 72 blazer. Has anyone done it here and can post up some pics?
Posted via Mobile Device Last edited by markedgar5; 06-20-2013 at 11:47 PM. Reason: Misspelled / typo |
06-20-2013, 11:42 PM | #2 |
Re: Thinking of turning a 67-72 bed into a trailer
I know of one that they used a rear coil spring truck and turned it into a trailer and it bounces all over hell and back and they absolutely hate it.
1969 Chevy C10 2wd stepside longbox |
06-21-2013, 12:05 AM | #3 |
I've seen a few of them around my area. If you have access to a torch and a welder it's not very hard to make one.
I'd really like to have one to match my truck too.
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
06-21-2013, 12:05 AM | #4 | |
Vintage 4x4s
Here is one i did from another C20 with a leaf suspension but it was before we figured out the storable tongue trick. The longer tongue allows sway free high speed operation.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
06-21-2013, 12:35 AM | #5 |
US Army Veteran
Better to get another 20 years out of it, as a trailer, than to see it sitting and rusting in a junk yard. Even worse, sold to China as scrap metal.
1972 C10 Highlander - The making of a daily driver |
06-21-2013, 03:16 AM | #6 |
I have one made from a c20 with leaf springs. I put a freebie fiberglass camper shell on it and use it for swap meets. It cruises at 70 all day behind my duramax like its not even there. The p.o. Cut the frame under the cab and lost interest(?) i bought it for the bed for a truck i was working on but sold the teuck and the new owner hada good bed, so i decided to do something with it. i bought a harbor freight hitch with one of the 20% off coupons so it was less than $30. We madepie cuts in the frame rails and heated it up and bent the rails together. I tacked the hitch on but had my dad (retired welder) weld it up along with safety chains and a spare tire mount against the bed front. I put a beat up tailgate on it and an old bent dealer bumper. I have about $100 not counting labor. It can be sen i the backgrou d of some of my for sale ads. Not pretty but definitely useful! Photos tomorrow
Posted via Mobile Device |
06-21-2013, 03:23 AM | #7 | |
When i first built it, it wasnt hooked to my truck and when i went to climb on the tailgate the trailer rared up in fron as it was almost perfectly balanced. I welded my hitch directly to the frame rails after they were pulled together (about where yours are) and still load all the heavy stuff up front, which is kind of a pain. I am considering bolting a toolbox in font to carry junk in to add tongue weight. Posted via Mobile Device |
06-21-2013, 03:26 AM | #8 |
06-21-2013, 11:46 AM | #9 |
my folks bought a 69 fleetside for $50 and were going to turn it into a trailer until the people who already did it told them how much they hated pulling there's. probably right just needed new shocks but it did save a good truck from getting cut in two. now I just need to find somebody to buy the truck before it turns into dust....
06-21-2013, 03:25 PM | #10 |
I've done several as they were being parted out, both coil and leaf. Put a good set of shocks on the coils and call it good. Any weight at all will flatten it out and it will tow like a dream. I have one that I still use to pick up dirt for the yard (leaf sprung). Between my truck and the trailer I can get 5 yards at a time. Made a scrap metal run about 2 years ago and had 3125# of metal in the trailer alone. Went over the scales at close to 12k with truck and trailer. Don't want to do that again.
06-25-2013, 12:38 AM | #11 | |
Vintage 4x4s
06-25-2013, 09:33 PM | #12 |
I am a Referee of life.
I see trailer sway comments all the time on single axle trailers.Almost every time I see a pic of said trailer the trailer is at an angle.The hitch needs to be set to keep the trailer level or nearly so to tow well.Tongue weight should be 10-15% of total trailer weight.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
