Old 06-21-2013, 12:52 AM   #1
c10 custom
pulley help
i have a 1950 chev truck and its a chev 383 stroker im having trouble with lining up a belt for the power steering pump pulley i have a 2 groove pulley on the pump and it wont line up with the balancer pulley or the water pump pulley i need some help guys
c10 custom is offline   Reply With Quote
Old 06-21-2013, 01:00 AM   #2
sqrlnts
Re: pulley help
long or short water pump? How many groove pulley on the crank?
sqrlnts is offline   Reply With Quote
Old 06-21-2013, 01:11 AM   #3
solidaxel
solidaxel's Avatar
Re: pulley help
There is some adjustment on the power steering pump pully.
You need a tool to remove and install the pulley and it may not have been lined up when it was put on the shaft
There should be one of the groves on the C/shaft that will match the pump
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-21-2013, 01:21 AM   #4
OrrieG
OrrieG's Avatar
Re: pulley help
assume long wp. stock ps brackets? 0post a pic there are a number of pulley/watrr pump/ps pimp combos.
OrrieG is offline   Reply With Quote
Old 06-21-2013, 10:56 AM   #5
mr48chev
mr48chev's Avatar
Re: pulley help
A photo (s) of what you have for brackets and mounts would help us be able to offer some solutions.
As the guys said, short pump, long pump? Then which brackets does the pump have as there are about three different styles.
With a couple of them you may be able to put a spacer between the bracket and the block or head to move the pulley forward enough to line up.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 06-21-2013, 01:05 PM   #6
c10 custom
Re: pulley help
hi guys the power steering pump pulley is 2 groove the water pump is 2
and the crank pulley is 3 groove and long water pump i appreciate the replys
Old 06-21-2013, 07:37 PM   #7
OrrieG
OrrieG's Avatar
Re: pulley help
Pic would help. When I was fabbing my mounts and had to change to a 3 groove pulley I got a pretty good education. You generally cannot mix 2 and 3 groove pulleys, the offsets are different and the diameters are different. I bought to independently before Kustombrad let me in on the secret and sold me a matched set. Long and short do not interchange. Some brackets mount off the front former engine mounts, some off the exhause bolt, some of a bracket on the water pump. Depending on where the alternator is the belts can be in different grooves. Show us what you have and we should be ablel to point you towards the right bracket.
Old 06-21-2013, 07:42 PM   #8
_Ogre
_Ogre's Avatar
Re: pulley help
shop air compressor timer
Old 06-21-2013, 10:43 PM   #9
mr48chev
mr48chev's Avatar
Re: pulley help
Ok, have you got the bracket that hangs the pump from the boss on the water pump or do you have it mounted to the block/heads? you need the bracket that mounts it to the water pump with a long pump.
