Old 06-21-2013, 10:16 AM   #1
Riley012
Interchangeable parts
I am new to this. I have a 1982 k20' I am looking at a 1985 K10 for parts. Can anyone tell me if the parts are interchangeable. Especially the body parts. Thanks
Riley012 is offline   Reply With Quote
Old 06-21-2013, 11:29 AM   #2
superwade57
Re: Interchangeable parts
Body parts and many many others are most of.these trucks are interchangeable watch for small differences
superwade57 is offline   Reply With Quote
Old 06-21-2013, 12:09 PM   #3
Riley012
Thank you, could you give me an example of small differences.
Old 06-21-2013, 12:48 PM   #4
Rubble
The front axle is the same,except for the rotor,backing plate and possibly the shoes.I have swapped parts back & forth on these,but can't remember about the shoes.Rear axle is heavier,probably a 14 bolt semi float in that year of truck.Might be a full floater.. Springs are the same length,just more of them in a 3/4T.(rear springs) That should be about all,if I missed something somebody will correct me ...
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 06-21-2013, 01:05 PM   #5
Riley012
Thanks, I want to switch the box, fenders and cab from the 85k10 to the 82k20.
Old 06-21-2013, 01:07 PM   #6
superwade57
That'll work
Old 06-21-2013, 04:34 PM   #7
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
The fuel necks for the fuel tanks are not the same, so you will need to use a 84-87 neck on your tank (s). Everything else is the same I believe on the bed.
The fenders are the same
Cab is similar, but not exactly the same, the biggest issue I can think of is the wiper switch location (not a big deal, just use the steering column out of the 85)
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-21-2013, 10:47 PM   #8
Riley012
If I use the steering column from the 85 how is it wired for the wipers.
Old 06-22-2013, 01:35 AM   #9
hatzie
Moderator
hatzie's Avatar
Is the 85 column a Tilt or has some other desirable feature? Or is the 82 cab beat to death??
In 83 GM moved the wiper switch to the Turnsignal stalk. Marrying an 83 or later column to the 82 cab harness would be an adventure but not impossible... given time, patience, and a full set of wiring diagrams for both years.
If you're swapping the cabs just keep the 85 cab harness and column. You can re-pin the 82 engine compartment bulkhead plugs to match the pinouts of the 85 cab socket. Most of them will probably match already.
I assume you'll be getting a current title to go with the VIN plate riveted to the 85 cab... That's the only real gotcha on a cab swap.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-22-2013, 01:41 AM   #10
hatzie
Moderator
hatzie's Avatar
The 6 lug 14bolt semi floater wasn't used till GM started building the T400 chassis trucks in '88... I'm not sure that it was even used on those in the 80s.
Old 06-22-2013, 03:35 AM   #11
Rubble
No,I was talking about the 14 bolt semi float 8 lug axle...I maybe read the op wrong,thought he had the K10 & was buying the K20 for parts truck.
Old 06-22-2013, 04:56 AM   #12
hatzie
Moderator
hatzie's Avatar
They started using the 8lug 9.5" 14bolt in 86 or 87 and only on the light duty 3/4 ton. There's almost no danger of ever seeing one of those.
Old 06-22-2013, 08:59 AM   #13
Riley012
The 85 does not have a title, the person that had it died in Jan. and his dad could not find it.Thanks to everyone so far that has commented.
Old 06-22-2013, 09:05 AM   #14
Riley012
Is it ok to keep the 82 steering, so I don't have to worry about the wiper switch and how about the cruise control. Thanks
Old 06-22-2013, 09:11 AM   #15
Riley012
I plan on removing all the body parts from the 85 and replacing the cab floor on the drivers side and the rockers on both sides this year. An start next spring on replacing the parts on the 82. The 82 has a 6.2 in it and I am not sure what the 85 has in it, the 85 was hit in the right fender but everything else seem ok.
Old 06-22-2013, 10:17 AM   #16
Rubble
Maybe it's a Canadian thing,my 82 K25 has a 14 bolt semi float & I have a 82K25 parts truck that had one in as well.The parts truck was original and almost positive the other is too.
Old 06-22-2013, 10:19 AM   #17
Rubble
The steering should be the same too for the most part.
Old 06-22-2013, 01:57 PM   #18
SamsAutoParts73-87
As far as I know the first year for the 9.5 S.F. is 81
I have owned an 81 K25 and 82 C20 and they both had the S.F.
-Sam
Old 06-22-2013, 02:02 PM   #19
SamsAutoParts73-87
Agreed
-Sam
Old 06-23-2013, 03:01 PM   #20
Riley012
It is a 14 bolt, how do you tell if it is a semi-float.
Old 06-23-2013, 03:49 PM   #21
SamsAutoParts73-87
Full floater looks like this.
-Sam
Old 06-23-2013, 03:52 PM   #22
SamsAutoParts73-87
Semi-floater looks like the rear axle on this 81 K20
-Sam
Old 06-23-2013, 04:55 PM   #23
Riley012
Can anyone tell me where you can get new wing window frames for the 82 k20.
Old 06-23-2013, 04:57 PM   #24
Riley012
I just looked, it is a semi-float. Thanks
Old 07-01-2013, 09:09 PM   #25
Riley012
Here are some pics of the 85 I purchased for the body parts, I noticed the gm stickers on the valve covers and somebody told me that it was probably a crate engine from gm. I checked the oil in the motor and the transmission and they both looked good. Does anyone have any knowledge of this.Name:  IMG_0006.jpg
