06-21-2013, 01:10 PM | #1 |
Quick front break question
Is it common with front disk conversions to have a wider stance in the front compared to the back? My front tires seem to be a lot closer to my wheel wells than the backs do.
What would it take to put 5 lug set up on the front? The front disk conversion was done with 6 lug. I know that I will have to put axles in the rear end. |
06-21-2013, 01:32 PM | #2 |
Re: Quick front break question
Yes it is common, My 71 from the factory is that way.
06-21-2013, 01:36 PM | #3 |
I am a Referee of life.
It's about 3/4 of an inch wider in front.Swapping to 5 lug will do you no good.The rear ends are wider in 71-72 to compensate.If you're running aftermarket wheels or wider rears,you can even it up some with wheel offset.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-21-2013, 01:55 PM | #4 |
Sorry the thought of swapping to 5 lug is for easier wheel selection, not to try and fix the width. I am ok with it I will just put a wider tire on the back to compensate for it.
