Old 06-21-2013, 01:55 PM   #1
blackout 77
front brake conversion ?s
Im trying to find info about which years and models that will change out with my 68 gmc. I want to put a 6 lug disc set-up on it. I dont have the money to buy new stuff (the good stuff) so im going from this truck to that truck getting parts. I want to keep my 6 lug set-up. Any help would be very appreciated.
blackout 77 is offline   Reply With Quote
Old 06-21-2013, 02:07 PM   #2
camrycurt
camrycurt's Avatar
Re: front brake conversion ?s
Welcome to the Board!
Have a look at this thread for factory 6 lug disc setups: http://67-72chevytrucks.com/vboard/s...d.php?t=578979
But be careful about your wheels - if you've got the stock drum steelies you may need to replace them to work with the disc setups: http://67-72chevytrucks.com/vboard/s...d.php?t=580148
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 06-21-2013, 08:03 PM   #3
Tinkermc
welcome to the forum
Tinkermc is offline   Reply With Quote
Old 06-24-2013, 04:33 PM   #4
blackout 77
I have 2001 gmc wheels on it right now. Just got off the phone with summit. Just have more important things to put a 1000$ on right now instead of breaks on my truck. I'll check them out and thanks
Old 06-25-2013, 09:09 AM   #5
MARKDTN
Disc brakes are a great addition to any old car or truck. You can have all the "go" you want, but if it won't stop-you are in trouble. You could get a 5-lug setup from a 73-87 easily and cheap. Convert the rear later.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-25-2013, 04:15 PM   #6
blackout 77
Theres a pullaparts here and they have a 82-87 silverado so I will look into getting it. Does anyone know if the cross member is rivoted in or bolted? Might go ahead and get the rearend also and can I use the booster pump and master cylinder off of that truck? I want to get differ wheels anyway so I might as well go ahead and change to 5 lug.
Old 06-25-2013, 05:18 PM   #7
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Crossmember is bolted in , if you are getting booster and master get all the lines too . They will fit with some tweaking.
ksbrktracer is offline   Reply With Quote
