Old 06-21-2013, 03:55 PM   #1
mknittle
mknittle's Avatar
solution to mustang gas tank issues
I found this and thought other people may be interested. note that the sender is on the top. and there is a selection of senders in different ohm ranges. the filler is also removable. kinda pricy though
http://www.tanksinc.com/index.cfm/pa...rod/prd129.htm
Mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-22-2013, 03:37 PM   #2
N.T.Q
Re: solution to mustang gas tank issues
ya it pricey but so are alum fuel cells
N.T.Q is offline   Reply With Quote
Old 06-22-2013, 04:41 PM   #3
mknittle
mknittle's Avatar
The best part is the adaptability.
Mark
My GMC build.
Old 06-22-2013, 08:35 PM   #4
Dan in Pasadena
Dan in Pasadena's Avatar
Doesn't strike me as pricey at all. Just over $200, what's new that's cheaper?
Yeah, 16 gallons isn't a lot and it makes you put the filler in the bed - I don't mind but I know some will. I had considered the Mustang tank before but thought you could only use a Ford sender so that wouldn't support my original gauge. At only 7-1/2" deep it'll be almost invisible once installed.
Dan in Pasadena is offline   Reply With Quote
Old 06-24-2013, 10:37 AM   #5
mknittle
mknittle's Avatar
Yeah, It really is worth the extra $50 over a mustang tank. The way I figure it the sender choice is worth it. the removable filler is a bonus. If a guy has the room a filler neck wouldn't be too hard to make.
Another bonus id that the dimensions for the mounting flange is right there.
For me that works I can make removable mounting frame. and paint it later.
I am trying to get all my mounting tabs Etc. done so I can paint the frame.
Mark
My GMC build.
