Old 06-21-2013, 08:26 PM   #1
Codez67Chevy
Codez67Chevy's Avatar
Air Shocks?
Has anyone used air shocks on their trucks? I know they don't work for any lowering purposes like using them like bags. I'm just throwing ideas around. I'm sure they make the ride very nice.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 06-21-2013, 08:47 PM   #2
flashed
Re: Air Shocks?
I have never used them on my trucks but I have them on my 72 El Camino which came factory installed and I hate them.
flashed is offline   Reply With Quote
Old 06-21-2013, 09:03 PM   #3
ecgate
ecgate's Avatar
Re: Air Shocks?
I had some on my truck when I bought it. They didn't ride that great, they leaked, and I wouldn't suggest to anyone using them.
ecgate is offline   Reply With Quote
Old 06-21-2013, 09:38 PM   #4
SS Tim
SS Tim's Avatar
Re: Air Shocks?
They were in fact a factory option G66 on some coil C10 trucks. Problem is they are really only good as a temporary load leveler. The more pressure you put in them the faster the ride turns to stone. The air lines are a maintance issue and if you don't keep a minimum of about 10 psi in them the bladders get trashed. Spring your truck for load you will normally carry and buy premium shocks. If you need an overload capability buy some Air Lift air bags. They do much the same as an air shock at a much lower pressure while still giving a reasonable ride.
SS Tim is offline   Reply With Quote
Old 06-21-2013, 10:05 PM   #5
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Air Shocks?
I have them on my truck, its lowered two inches in the front and has 3 inch blocks in the back. I love them cause I can raise the back a Lil and have support when I haul something in the back. They are monroes
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 06-21-2013, 10:51 PM   #6
haysonj
haysonj's Avatar
Re: Air Shocks?
This is what I use and is good up to a 1000 pounds
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 06-22-2013, 12:36 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Air Shocks?
Had factory air shocks in my '69 El Camino -- steel air lines instead of typical nylon aftermarket lines. No trouble with them but I only kept the Elky about two years. Like others said, they aren't for a soft ride, but to stiffen the ride for heavier loads -- or in my case, to keep the rear fenders off the L70-15s on 15x10 chrome wheels. 100# pressure did it, but it rode pretty firmly.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-22-2013, 07:06 PM   #8
kcsa75
kcsa75's Avatar
Re: Air Shocks?
x2
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 06-22-2013, 10:00 PM   #9
Square_78
Square_78's Avatar
Re: Air Shocks?
Air shocks work awesome. I have them in the back of my 1978 c10. With 80psi in the shocks I can carry 600lbs of dirt bikes no problem and never bottom out. With no air in the shocks, the axel touches the frame when you stand in the back. You get about 2 lift with the shocks. Definitely not as good as an air bag for height adjustment, but they do the job if you need an inch or two of lift or need to carry extra weight. Plus they are cheap and bolt right in.
Mine ride great and don't leak. If yours are broken then replace them with new ones and you will see how nice they can be. Highly recommended for anyone on a budget or looking for an easy fix.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 06-23-2013, 08:31 AM   #10
Re: Air Shocks?
x3
I have them on my '72 K2500. They were on there when I bought it in '01 and still work and ride fine. The truck hauled a 5th wheel travel trailer and is so equipped (extra cooling,trans temp gauge,proper mirrors,brake controller,wiring...).There are air shocks made for cars,like Hijackers,and air shocks made for trucks. I remember when everyone was running Hijackers they were always blowing out. Just cheap aftermarket crap exploiting kids who "gotta have it". Maybe that's where the myth got started. Maybe a lot of those weren't installed properly
