Old 06-21-2013, 10:39 PM   #1
81Scottsdale520
81Scottsdale520's Avatar
Carburetor help!!!
So i bought a brand new Edelbrock 600 cfm, BUTTTT the EGR valve is getting the way so i unbolted the EGR then put the carburetor on along with the adaptor but now i cant put the EGR valve back on because it hits the electric choke and doesnt allow me to bolt it back on. Anyone have any suggestions? i really want my truck back on the road so PLEASE HELPPPPPP!!!!
~When In Doubt Go Lower~
81Scottsdale520 is offline   Reply With Quote
Old 06-21-2013, 11:12 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Carburetor help!!!
Do you really need the egr?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-22-2013, 01:30 AM   #3
Redcap
Remove EGR, throw in trash. Problem solved.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 06-22-2013, 04:02 AM   #4
81Scottsdale520
That's what I'm wondering if I need it or not? If I remove it would I have to cover it or plug it?
Old 06-22-2013, 06:28 AM   #5
Dead Parrot
Do you have to pass an emission test? If not, remove the EGR. You will need a cover plate. Also, if you are planning on using a OEM air cleaner, you may need a banjo gas line adapter.
Dead Parrot is offline   Reply With Quote
Old 06-22-2013, 06:45 AM   #6
INSIDIOUS '86
Could get a Holley and fix all problems haha
Old 06-22-2013, 07:35 AM   #7
81Scottsdale520
No I don't need to do emissions and I was looking for a Holley but they had this one for a good price so I got it haha I need to find a cover plate and different air filter is that right?
Old 06-22-2013, 07:46 AM   #8
81Scottsdale520
Also where can I find this cover plate? I've looked on the website of AutoZone but can't find it anywhere unless I'm not looking right?
Old 06-22-2013, 08:33 AM   #9
bigd65
bigd65's Avatar
Cover plate or they sell an extension plate I believe. I had the same problem on my 85
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 06-22-2013, 08:46 AM   #10
Sodell
Sodell's Avatar
It probably wont be on their website, but they should have one at the store. I think they are called EGR block off plates.
Mr. Gasket EGR Block-Off Plate Kits 7631
Sodell is offline   Reply With Quote
Old 06-22-2013, 08:58 AM   #11
81Scottsdale520
Thanks guys! Huge help I almost was gonna take return the carb !
Old 06-22-2013, 09:45 AM   #12
i8tokyo
EGR block-off plate is a Weiand 9007.
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles
1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles
If it ain't broke, there is still probably room for improvement.
Speed costs money, how fast do you want to go?
i8tokyo is offline   Reply With Quote
Old 06-22-2013, 10:03 AM   #13
81Scottsdale520
Ok got it, gonna head over to AutoZone in a few minutes to get it
Old 06-22-2013, 11:31 AM   #14
81Scottsdale520
Of course, no luck at autozone
Old 06-22-2013, 11:50 AM   #15
wraprail
wraprail's Avatar
I have awalys just made my own out of some 1/4" aluminum flat stock.
wraprail is offline   Reply With Quote
Old 06-22-2013, 12:00 PM   #16
81Scottsdale520
thats what i was thinking but i have no kind of metal nor the tools to do it myself
Old 06-22-2013, 01:26 PM   #17
Kingjasn
Kingjasn's Avatar
if you got some tin snips, a thin piece of sheet metal and a marker, you got all you need. take the egr off and trace the shape on the sheet metal. cut it out and drill holes for the bolts. might have to stack washers if the bolt holes in the manifold don't go all the way through. this would be a temporary fix until you could get tools or a friend with tools to make a more permanent solution.
Kingjasn is offline   Reply With Quote
