06-22-2013, 08:14 AM | #1 |
Rear brake seizing..... help!
What's the common reason my rear drums would lock up? Lock-up as it feels like I'm driving with emergency brake on. It was hard to rotate rear tires while off the ground. I first disconnected e brake cable wich didn't help. Only by opening driver side bleeder valve releaseing a litile fluid out solved the problem. I took the same 3 mile test drive back home and felt it starting to seize up as I got into drive way. I'm thinking the problem is from exhaust heat or wheel rotation? Stainless steel brake lines have about 1 inch clearence from headers as it passes frame rail from proportion vavle. In the past i have let the truck idle for about 30 min before atempting a test drive. I have front disc brakes stock rear drums with internal rebuild kit.......entire brake system is new except emergency brake cable and brake pedal. 68 suburban only have about 6 miles since rebuild.
Posted via Mobile Device |
06-22-2013, 08:45 AM | #2 |
Re: Rear brake seizing..... help!
Rear shoes adjusted too tight ???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
06-22-2013, 08:47 AM | #3 |
its always best to run brake lines as far from heat as possible...but I don't think that's your current problem...heat will boil the fluid resulting in no pedal...even if it were expanding it would just flow back into reservoir...unbolt master from booster when it happens,i think pushrod is too long
06-22-2013, 09:01 AM | #4 |
X2 on the pushrod clearance problem
06-22-2013, 09:38 AM | #5 | |
06-22-2013, 09:39 AM | #6 |
06-22-2013, 09:56 AM | #7 |
the hard/soft situation is normal,thats just the power assist kicking in when the engine is started and booster gets vacuum...search other threads for adjustment,mines manual so i'm not positive...usually rod in booster is threaded...you just want a tiny bit of clearance between it and master..you shouldn't have to push on master to get it to touch booster(not easy to feel now that lines are on)
06-22-2013, 10:27 AM | #8 |
Proprietor of Dale's Corner
If releasing fluid helps, you may want to replace the rear flex hose. They get old and the inside collapses. The master has enough pressure t push through it but the return springs can't return it all and brakes drag
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-22-2013, 01:02 PM | #9 |
If you can pull the drums off with little effort then the shoes are adjusted ok. Make shure all your springs and hardware are installed correctly. some guys like to have the shoes drag on their drums and some dont.
06-23-2013, 05:20 PM | #10 |
.....I just unbolted master to see if I could see push rod.....I don't. Is this normal when vehicle is off?
