![]() Join Date: Apr 2012
Drive shaft length for 700r ?
Does anyone know the correct length I need to have my drive shaft cut down to inorder to run a 700r
Current setup 350 SB with TH350 Posted via Mobile Device |
Re: Drive shaft length for 700r ?
to only pay havein the driveshaft done one time it is best for you to measure for yourself a few times to make sure of what you need
![]() Join Date: Apr 2009
Reamber when doing Mesureing for new shaft Truck needs to be at ride hight!!!!
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
![]() Join Date: Mar 2013
Definitely measure yourself. If its a 2 piece you would want to measure from the center of the 2 bolts that hold the center bearing to the tip of the output shaft at ride height. If 1 piece measure from the tip of the output shaft to the flats of the yoke. Some shops like to measure from the end of the tail shaft instead of the shaft itself minus the seal but either way would work as long as they know wht you measured, just make a note of how much shaft stick out you have out of the tail shaft just in case they want to know, mine was like 3/4 inch.
the boat guy
What they said. If 2 piece take them both pieces so they can ballance your shaft as an assembly.
I build driveshafts, good to see my advice is sinking in with the locals ![]() Posted via Mobile Device |
Thanks guys for the help and tips. It's a one piece shaft.
PIctures or diagram would help big time. As I am getting ready to put a 700r4 myself.
Carpe manana
![]() ![]() Join Date: Dec 2010
When I installed a 700r4 the engine was moved forward 1.75" so as to avoid cutting the drive shafts. This was in a 4x4 though. Can you just move the engine mounts?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Yes I can. My motor is sitting on the back mounts right now. More than likely. I'm going to measure once its all done just to avoid any issues. I was thinking of getting it cut before if it was a set or exact amount every time.
