under hood paint
Any opinions on whats a good under hood paint?
Re: under hood paint
I don't see a problem using same paint on both sides of hood. One no breather back firing carb did burn paint on both sides; not really paints fault though.
![]() Join Date: Jun 2012
Using the same paint on the whole truck
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
just my 2 cents but when I paint a hood I paint both sides 2 match, plain paint or graphics
Carpe manana
![]() ![]() Join Date: Dec 2010
Funny just dealt with this issue this week on my K20 build, which I'm kinda trying to keep OEM with a few exceptions. As far as I can tell, GM kept the under surface of the hood (if that's what your post references) black - the EDP or whatever coating that came on all hoods and sheetmetal pieces like doors. The top of the hood and sides that are visible when the hood is shut are painted to match the body. This is the scheme I'm replicating. A body color matched hood under surface is a give away to a repaint but may appeal to some folks and that's cool too.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I can go w/ OEM color scheme. Some years have body color under hood. Didn't know some came black but did know some came w/ that insulation stuff that falls off after several years.
Guess I should clarify
Which type of paint last longer? Is it worth the time trying to keep gloss looking good or go with a flat? Ive had problem with gloss standing up to the heat ( maybe I got some cheap stuff) |
![]() Join Date: May 2013
look into a paint called "mothane" is great for general purpose , easy to mix and spray,and is very tough
#9 | |
I know PPG and Dupont auto body single stage and clear coat systems do well under hood. |
