Old 06-22-2013, 08:10 PM   #1
DreamRyder1963
DreamRyder1963's Avatar
Starting Issue (Possible Ground Issue)
I am having trouble getting my 71 C10 to start. The radiator went out last week and the truck sat for a couple of days till the new radiator came in. Well when I got everything back together the truck would not even engage the starter. The brake light in the cluster would come on and thats it. I jumped the solenoid and it started to turn the truck over but it was very slow so I replaced it with a known to be good starter. It still did not start the truck. I decided it had to be a bad connection somewhere so I replaced the cable ends and tighten all the connects I could find. Nothing happened so I swapped the battery (a brand new Optima Red Top) and it started finally!
I drove my truck to work yesterday and on the way I had a new hose blow out on me. I pulled over and let it cool off. When it cooled off I tried to move it to a safer place and the truck would not start! I figured that the solenoid was simply heat-soaked and would be fine later.
This morning I fixed the hose and it still would not start. I decided it must be a ground issue so I disconnected and cleaned the connection at the block and checked a seperate ground someone attached to the fender. It still will not start. I took both batterys to work today, I work at Advance Auto, and checked them. It looks like the Optima is fried but the other battery has 1100 cca. Last time I checked that should start a stock 350 with no troubles. I could use any ideas on what I might have missed. Thanks for your help.
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 06-22-2013, 08:25 PM   #2
Zable49
Zable49's Avatar
Re: Starting Issue (Possible Ground Issue)
I would check your fuseable link (+ cable from post to fender)... I would also check your main harness at the firewall. I've had the firewall block curoded causing the starter to not get signal to turn over. Then if thats not it. I know you said you checked you grounds, but I would make sure its grounded at these locations with no grease and paint in between your wire and item-
Battery to motor
Motor to body
Body to frame
Good luck, let us know what ya find.
1970 C20 Camper Special
SBC350 / TH350
'84 C20 Front Disc Brakes/Control Arms
Zable49 is offline   Reply With Quote
Old 06-22-2013, 10:15 PM   #3
DreamRyder1963
I by-passed the fuse-a-ble link by directly connecting the wires together so that should not be a problem. I will try to check and reinstall all the grounds with dielectric grease tomorrow.
Old 06-23-2013, 01:19 PM   #4
DreamRyder1963
I noticed these relays on the firewall while I checked the wiring harness. Does anyone know what they control?
Old 06-24-2013, 04:34 PM   #5
DreamRyder1963
I figured out what the relays on the firewall were to. Appratently they are for the TCS and therefore not likely to be my problem. I have cleaned and greased all of the grounds within the engine bay, and I still have the same problem. I do not think it is the igition switch since the brake light on the dash appears when I try to start the truck but I can not think of what else it could be.
Old 06-24-2013, 08:37 PM   #6
Don Quixote
Don Quixote's Avatar
Sounds like your starter celenoid is giving up the ghost. Does it start when you put the screwdriver shaft to the leads?
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 06-25-2013, 09:23 AM   #7
DreamRyder1963
It sounds like the starter spins but does not extend. I guess its time to change the starter again.
