Old 06-22-2013, 09:05 PM   #1
Southern Shaker
71' 350 Questions
So i picked up this 73' cheyenne super friday and took a look at the motor before i made my run this weekend its a small blo9ck 350, had my uncle get me some info on it. well he called me today an told me the Guy that was Building the truck pulled the engine from a wreck 71 squad car he used to have in his junk yard. the motor is "Supposably supposed to run Strong but who know . Now what i would like to know is , Is there anyway to find out if its a 4 bolt main by Any of the numbers on it? i know i could pull the pan . But i just thought id ask this question first?
Southern Shaker is offline   Reply With Quote
Old 06-22-2013, 09:08 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 71' 350 Questions
As far as I know the only way to know for sure is pull the pan. The "010" casting number will not tell you.
TBONE1964 is offline   Reply With Quote
Old 06-22-2013, 09:10 PM   #3
Southern Shaker
Haha dang i was hopin there might have been an easyer way , Trucks Lowered a bit an im on the larger side of life haha oh well on the lift it goes i guess
Old 06-22-2013, 10:59 PM   #4
slow-1
slow-1's Avatar
On the drivers side of the block on the rear "ledge", where the transmission mates, there is a casting #, you may find out with that number.
slow-1 is offline   Reply With Quote
Old 06-22-2013, 11:25 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Usually a four bolt will have the 010 number and a oil galley plug above the timing chain cover
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-23-2013, 05:59 AM   #6
cdowns
cdowns's Avatar
4 bolt main engines are aboout the most foolishly overrated things by dweebs ever
Old 06-23-2013, 06:32 AM   #7
jjzepplin
jjzepplin's Avatar
If it's a 2 bolt main and runs good, Why take it apart? Who cares as long as it runs? Built correctly they are very comparable. I've never seen a main break. Bearings go bad yes.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-23-2013, 07:36 AM   #8
TBONE1964
Cluster King
TBONE1964's Avatar
As a professional engine builder for 15 years of my life, I will again say that the "3970010" casting number does not designate a 4 bolt main block, it does not even mean 350. Yes it is likely a 350 but could also be a 327. I want to clear that up for anyone who may have questions concerning that casting number.
Attached is a casting number guide for blocks and cylinder heads.
As far as strength of the block, unless you are zinging the thing over 14,000 RPM's you really will see no benefit from using a 4 bolt main block.
http://www.thedirtforum.com/castings.htm
Old 06-23-2013, 10:07 AM   #9
LONGHAIR
This ^^^ is just a more tactful way to say this......
Originally Posted by cdowns View Post
4 bolt main engines are about the most foolishly overrated things by dweebs ever
Agreed either way
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-23-2013, 10:18 PM   #10
slow-1
slow-1's Avatar
As an amatuer engine builder of 30 years, I completely agree with both of your points.
