![]() Join Date: Aug 2012
Bumper brackets
Can someone post a picture of front bumper brackets. On the truck. Thank you.
Posted via Mobile Device |
#2 | |
RAT1968 '68 Cab/'71 Parts
Re: Bumper brackets
I went under and "finger-tightened" the pass side bracket and took a pic for you. But first, I laid them both on the ground to show the "lay out". In the last pic, the bracket runs a little higher when fully tightened. If you would like a tip, tighten the two small brackets that are shown attached to the bumper to spec. Then, everything else goes on loose until you have 'em all in. Then again, you probably don't need a tip.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
