Old 06-23-2013, 11:14 AM   #1
williamsboys
williamsboys's Avatar
at salvage now, are these rare or even from this area
http://
http:// by
Williamsboy
williamsboys is offline   Reply With Quote
Old 06-23-2013, 11:19 AM   #2
tincan1966
tincan1966's Avatar
Re: at salvage now, are these rare or even from this area
Nope, just a cheap set of aftermarket gauges that someone hacked up a good dash to install. I know that's harsh, but sure hate seeing this.
tincan1966 is offline   Reply With Quote
Old 06-23-2013, 11:43 AM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
The Stewart Warner gauges were quality built and popular when new, but are also rather common and readily available. The Sunpro gauge wasn't worth much when it was new. I agree with Tincan, it's a shame to see the modifications. Thanks for asking though, you never know, the next item you find might be the Holy Grail!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-23-2013, 11:54 AM   #4
williamsboys
Yep thanks guys
Williamsboy
Old 06-23-2013, 12:53 PM   #5
williamsboys
http://
Would this power steering set up work on a 327? Can u change the pullys on these?
Williamsboy
Old 06-23-2013, 01:07 PM   #6
williamsboys
Or is this better of this inline 6? I have the Gilmer drive pulleysand I no I just need the v belt pully for mine. But will this mount on a 327
http://
Williamsboy
Old 06-23-2013, 10:32 PM   #7
awbrown
the 6 cyl power steering setup is gold ,I would snag it for sure , the V8 stuff looks like it may be for AC but I am not sure .... a keeper also in my book.. Even though I do prfer the late model serp. belt ....
awbrown is offline   Reply With Quote
Old 06-23-2013, 11:20 PM   #8
63burban4x4
63burban4x4's Avatar
the v8 stuff is not original 283, or 327, I don't think.....large harmonic balancer, long water pump, later PS pump (no nut holding the pulley) and those exhaust manifolds are later. No oil filler tube on the intake, and extra vacuum or PVC hoses, etc. That looks like a 350 to me. The stuff probably could all work on most any v8, but not for an original setup. The original PS brackets for our trucks don't look like that, but that may be for an A/C setup in later years? I don't think older 327 heads would have the mounting holes for those brackets.
63burban4x4 is offline   Reply With Quote
Old 06-23-2013, 11:23 PM   #9
pestwagon
I like the thrift air knob....picture #1
pestwagon is offline   Reply With Quote
Old 06-23-2013, 11:32 PM   #10
Captainfab
60-66 Nut
I agree with awbrown on the 6cyl PS pump. I would get that including the pulleys and idler and alternator bracket. Those are getting harder to find.
Regarding the small block PS. That pump and brackets will only work if you have a small block with a long water pump and heads with the accessory holes. You could use the pump itself, but not the brackets.
