06-23-2013, 12:18 PM | #1 |
automatic steering column
Has anyone done a three on the tree swap to automatic if so what all will work and how far in year model can I go I'm working on a 1969 i need linkage column and everything thanks
Posted via Mobile Device |
06-23-2013, 03:26 PM | #2 |
Re: automatic steering column
I've been thinking about doing this to my '69 gmc for years. In fact, I have a parts truck with just about everything to do it. (it just hasn't been a priority)
The easiest way is to find a complete truck (67-72) and swap parts. You will need to remove the 3 spd bellhousing crossmember (riveted in place) and use one that mounts on the transmission. And swap steering columns and possibly driveshafts. If you use a TH350 trans (and I think 700r4), you will have to hook up a cable to the throttle. The TH400 trans uses an electric kickdown you'd have to run wiring for. I think just about any year trans will work, but the column, linkage, and crossmember will need to be 67-72. My information may not be 100% accurate. Hopefully somebody else can tell you anything I've missed. |
06-23-2013, 05:52 PM | #3 |
Thanks castiron that is some good info and yeah those rivets are a pain lol
06-23-2013, 06:07 PM | #4 |
I got a good used colum off of ebay for 100 bucks. I had to get the intermediate shaft as well as mine was a one piece column. Then bought the aftermarket shift linkage kit from LMC...
Works great... only thing I found is that the needle doesn't line up on "D" all the way... Posted via Mobile Device
1971 Chevrolet C10 Inflation Fighter 1994 C3500 Crew Cab Dually 454
06-23-2013, 07:13 PM | #5 |
Cool that's what I was hoping for thanks c10monkey
06-23-2013, 07:30 PM | #6 |
just finished mind, swapped out the column and got some linkage from LMC .
