Old 06-23-2013, 02:16 PM   #1
Don Quixote
Don Quixote's Avatar
Use For the Stock Amp Guage
The new wiring kit I installed in my 72 last year didn't allow for wiring up the stock amp guage and for good reason with most running 100 amp alternators these days.
I did however, find a use for an otherwise dead guage.
I pull a lot of trailers and most of them have electric brakes that run off of a 40 amp circuit breaker. Since the guage will handle up to 60 amps, I found that I can run the brake line off of my trailer brake module through the guage and block off that portion of the printed circuit. I can now get a basic assessment of what my trailer brake is doing much like the air brake pressure guage in a semi-truck and not worry about catching my dash on fire.
As a last resort backup, I have a brake light cutoff switch on the dash, normally so I can use my hazards while I back up and bypass the trailer brake to do so. If I were to ever have a problem I can throw the switch and power will be cut to that circuit as well.
Be sure you use the exact same guage wire (usually 12awg) to make this circuit and when you test it, if it reads a discharge, just reverse the wires and be sure not to peg the thumb switch as it will peg the guage. This is useful for things such as brake leveling and power adjustments.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 06-23-2013, 02:25 PM   #2
jjzepplin
jjzepplin's Avatar
Re: Use For the Stock Amp Guage
Nice! ! !
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-23-2013, 02:27 PM   #3
Prematuregrey
Prematuregrey's Avatar
That's a handy idea.
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline   Reply With Quote
