Old 06-23-2013, 03:47 PM   #1
aficio
distributor and advance
1987 r20 pickup 454
All: in fighting my bogging problem, i replaced the pickup coil in the distributor, when I was removing it and before I loosened anything I marked three points on the unit and once i put it back in i lined all three points up, but when i started the truck up i had to rotate it almost a halve the distance to the next plug. and with the timing set i am not even close to my marks, actually quite a ways off. any ideas what would have caused it. In the original position my crankshaft mark is not even visible, it is about 12 o'clock instead of matching on the indicator to set my degrees.
thanks
aficio is offline   Reply With Quote
Old 06-23-2013, 04:40 PM   #2
Desert1957
Desert1957's Avatar
Re: distributor and advance
Timing on these "TBI" engines is not like any other square.
Its been covered many times but there is a wiring plug near the master cylinder , on the firewall which must be unplugged to set base timing.
http://67-72chevytrucks.com/vboard/s...ght=TBI+timing
Desert
Desert1957 is offline   Reply With Quote
Old 06-23-2013, 05:41 PM   #3
Sodell
Sodell's Avatar
And after you unplug, set timing at zero.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 06-23-2013, 06:38 PM   #4
aficio
Thank you, thank you, my manual does not say a thing about this and i could not figure out what i could have possibly done, i appreciate it very much.
Old 06-23-2013, 10:32 PM   #5
aficio
So even though the truck say's 4 btdc. you set it at zero? so does the computer take it to 4 btdc once you hook the line back up and clear any codes?
Old 06-23-2013, 10:55 PM   #6
Sodell
Sodell's Avatar
If it is a TBI, you set it at 0, the ECM will take care of everything.,
Scott
Old 06-23-2013, 11:19 PM   #7
aficio
thank you. Will reset tomorrow night and see how it works
