06-23-2013, 06:19 PM | #1 |
Trailer towing specs for a '67 GMC with a dealer installed bumper
Anyone know what the maximum tongue weight/trailer weight specs are for the standard dealer installed bumper?
06-23-2013, 08:23 PM | #2 |
Re: Trailer towing specs for a '67 GMC with a dealer installed bumper
Now thats funny!
If it is not stamped on there you need to make an educated guess. If you are towing a trailer heavy enough to raise the question buy a receiver hitch that mounts to the frame. Remember the factory recommed equalizer hitches on truck/trailer GCW of 8500lb and up and suggested them down to a GCW of 6500lb. The aftermarket numbers I can easily lay my hands on are a very conservative SAE Class 1 which at the time was 2000 /150. But I'd suspect that a SAE Class 2 is probably applicable to some of the heavier bumpers which would be 3500/250. Remember that most of the dealer installed bumpers were for profit margin not the best and heaviest. Look carefully at the construction, some are simply a series of tack welded plates and channels.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
