AD interior windshield trim
Talked to a guy at the local Rod shop yesterday, he says nobody remakes the AD interior windshield trim. Is this true? Is there no company out there reproducing this piece? My searches haven't turned up anything, but maybe I'm not using the right vocabulary.......?
Ryan Posted via Mobile Device |
Re: AD interior windshield trim
you are correct, i'm in the same boat.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Well, looks like the search is on for a usable original then! I don't mind the look of it with no trim, but I fear my defrost vents might dry my contacts out before the windshield clears up!
I might be a little crazy, but why not use some old (or new if you'd rather) vents? Cut them about an inch down from where they mount under the dash and perch them on top aimed towards the windows? Should help fix your dried contacts. And no, I don't have the interior trim either.
#5 | |
![]() ![]() Join Date: Nov 2008
Yeah I got luckey on mine especially. The best rout to go is find an old cab with a decent interior and restore the trim. My interior was all in my truck but I don't have an engine runing or a bed. My cab needs some work to.
![]() Join Date: Oct 2007
here is a complete set on ebay. $75.00. here is the item #130901710759. hope this helps.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
Following the radio delete plate I think the window trim is the second thing that is missing out of most cabs you find sitting around.
I'm in a similar situation on the cab molding that goes around the door. It's not the floating type like the late 49-55. My mettal striping broke on the drivers side and has rusted out on one portion. I'm thinking about trying to reproduce them myself. In the latter years you could only see rubber on mine you can see a mettal stio that went over the robber.
#12 | |
#13 |
That actualy would not be a bad idea. All the windlace channels I have seen are for the 49-55 but I my even be able to find a portion of it off another truck and stick them together. Mine are bent very badly but I can straiten them out.
