06-29-2003, 01:18 AM | #1 |
C10 now is a GMC
Lowering blocks
Hi Everyone,
I'm wanting to lower the rear end on my '62 C10 using lowering blocks. I've got a custom made set for the rear end, but i'm needing 2 inch longer U bolts. Where's the best place to find them, if not is there a place I can get them specially made? TIA, David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
06-29-2003, 10:00 PM | #2 |
Fabricate till you "puke"
Try a local spring shop, in my area I can have them made while I am on lunch break & they run about $25-30 for u bolts ,nuts & washers. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-29-2003, 10:01 PM | #3 |
Hi. Look in your Yellow Pages phone book under Springs. Any good 4x4 shop or spring shop should be able to make them.
I have a local shop that makes them for $20.00. Ask the 4x4 owners in your area also. |
06-30-2003, 04:09 PM | #4 |
Nothing clever
auto parts
try the local auto parts store. They usually have them to go with the Lowering/lifting blocks that they sell seperately.
I just saw them yesterday at Kragen. |
07-01-2003, 05:34 PM | #5 |
C10 now is a GMC
Thanks Everyone
David
08-04-2003, 03:13 PM | #6 |
Rockers1/2"off the ground
Hey chevyboy what size rims you running? I was thinking about lowering blocks too but more than 1 inch will be sticking down past the bottom of the rim which is not good .. and not legal too i think?
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca |
08-04-2003, 06:55 PM | #7 |
Try Early classics or Classic perf Products. One or the other sold longer u-bolts @ one time because that's where I got mine.
I use 1.5" blocks w/15's and haven't had any probs on my beater.
08-04-2003, 10:43 PM | #8 | |
C10 now is a GMC
David
08-07-2003, 10:50 PM | #9 |
I would be interested in seeing a pic or two, I am looking at lowering my 69 about 4" and was not sure if I should go just 4" springs , since it may stick down to far with blocks.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
08-08-2003, 08:38 AM | #10 |
Just thought I'd pop in here and say...
hurry up and slam that thing with some nice 18's |
08-08-2003, 11:58 AM | #11 |
how far can you lower your trucks with these? Are these just the clamps that you put on your springs and tighten them down? How is your ride quality after this? Do you need to switch your shocks at all? Just full of questions today
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
08-08-2003, 08:28 PM | #12 |
This is what a lowering block looks like
So basically your suspension stays the same and it is your axle that sits higher, but it will keep the proper angle for the driveshaft. The only thing that I am worried about is that I want to go 4 " and I don't want the bolts to stick down further than the rims.
08-09-2003, 01:08 AM | #13 |
Out of the carpool lane.
Chevyboy1962, I have some longer U bolts for you. $10 + shipping. Mine are round on top unlike the square style shown above. They're for a coil setup. Send me your email address if you want the pic.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 08-09-2003 at 01:14 AM. |
08-09-2003, 03:17 AM | #14 |
C10 now is a GMC
Hi Brad, thanks for the offer, but I already bought a set.
Here's a pic with the 2 inch lowering blocks installed. http://community.webshots.com/photo/...79603892GYyAXL It's not as low as it shows in the pic, the tire is also low on air. I also put on a set of spring compressors on the rear coils that made it another 2 inches lower. I plan on purchasing 2-3 inch lower coils for the rear, or go with air bags. Since lowered, the front + rear handles like she has sway bars on both axles. She handles pretty nice around sharp 90 degree turns, and flies over bumps in the road. Slammed in the weeds rolling on some 18's would look sweet. Who all carries 6 lug 18's, and what size tire should I run? David
