Old 06-24-2013, 12:16 AM   #1
BLUE THUNDER
BLUE THUNDER's Avatar
What brand of brake booster did you use?
Back in 2010 I bought a crappy Autozone brake booster to get it running. It has done an o.k. job until now. It feels like I'm losing vacuum when it apply the brakes. The pedal bottoms out and it doesn't stop as quickly as it used to. I checked the brake pads and there's plenty of meat on the bone. What else could it be? I'm sure it's the booster. What manufacturer have y'all gone with?
BLUE THUNDER is offline   Reply With Quote
Old 06-24-2013, 08:16 PM   #2
AJs72K5
AJs72K5's Avatar
Re: What brand of brake booster did you use?
I'll ask the dumb question...you sure your vacuum hose to the booster is good?
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-24-2013, 11:58 PM   #3
BLUE THUNDER
Let me check. How's the Blazer? I haven't seen it anywhere. Give me a shout 210-248-4196.
Old 07-20-2015, 12:48 PM   #4
Billyburban
Did you ever figure your breaks out cause my 70 suburban is the same way I have to double pump it to build pressure then I will stop
Billyburban is offline   Reply With Quote
Old 07-20-2015, 02:34 PM   #5
Onalaska Blazer
Bleed your brakes, bad booster would not cause you to pump them, bad booster would make them hard to depress and very hard to stop. You would need to stand on the pedal to get them to stop
Onalaska Blazer is offline   Reply With Quote
Old 07-20-2015, 02:49 PM   #6
Billyburban
I took it to a shop they bled the brakes I bled the brakes replaced brake line houses in front Newport News valve new master cylinder new brake booster. If you press the break once it slows it down but if you need to make an abrupt stop you have to double pump it
