Old 06-24-2013, 11:49 AM   #1
xaircav
xaircav's Avatar
Show me your hood props
The original hood hinge springs ('53 AD truck) sagged and made the hood a head knocker and the new ones are so strong they push the back of the hood up off the cowl. I need some hood prop ideas other than a broom handle.
xaircav is offline   Reply With Quote
Old 06-24-2013, 12:34 PM   #2
coralhead
coralhead's Avatar
Re: Show me your hood props
Have you gone through the correct process to align the hood? If not followed correctly the back of the hood will be lifted from the cowl.
coralhead is offline   Reply With Quote
Old 06-24-2013, 12:41 PM   #3
mr48chev
mr48chev's Avatar
I used an old broomstick when I didn't have the springs hooked up but the hood always lifted up in back and never seemed to fit right without the springs.
My ongoing truck projects:
Old 06-24-2013, 02:58 PM   #4
xaircav
xaircav's Avatar
I've done the hood adjustment using my repro assembly manual and everything looks great untill I hook up the springs. The center of the hood lays lightly on the rubber seal but the ends are pushed up and flutter at hiway speeds.
Old 06-24-2013, 04:44 PM   #5
mknittle
mknittle's Avatar
Maybe adapt a pair of hatch back gas cylinders.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-24-2013, 04:52 PM   #6
fabguy
Elev8r Man
fabguy's Avatar
I am going to use a piece of clear polished anodized aluminum tubing to hold it up
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 06-24-2013, 04:56 PM   #7
vegadesign
vegadesign's Avatar
heres mine in the making
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 06-25-2013, 01:26 PM   #8
_Ogre
_Ogre's Avatar
knock out the prop rod and it will be a decapitator
why not fix the problem rather than booger it up?
shop air compressor timer
Old 06-28-2013, 03:01 PM   #9
judd55
Had this problem with both my 55 Ponch and 55 GMC even with new springs. My solution was to set the hood to the position I like and measure the length of the springs then cut a piece of coat hanger wire slightly longer than this measurement, and bend hooks in the end. Now raise the hood slightly higher and slip each end over the spring. One will hold the hood up but, one on each spring is safer when working under there. You can still close the hood and not damage anything if you forget they are there, the ends will straighten out under tension. I use a small rare earth magnet to secure them out of sight under the hood when not in use. ............... Works for me
judd55 is offline   Reply With Quote
