06-24-2013, 07:57 PM | #1 |
Suspension sag
Ok so I bought my truck already lowered which I'm thinking may have been a mistake. My passenger side front tire rubs the wheel well on almost every bump but my driver side never rubs. So I investigated real quick and snapped two pictures. The passenger side bump stop is buckled. What do you think caused this. My truck is dropped 5.5/7
Passenger side Posted via Mobile Device |
06-24-2013, 07:58 PM | #2 |
Re: Suspension sag
Driver side
06-24-2013, 08:05 PM | #3 |
67-72 parts collector,…
Re: Suspension sag
Does your truck have drop spindles?
Pull the rubber snubber and remove the mount. This will give you added travel. If it's too low, replace the coil springs. No mistake that can't be fixed,...
06-24-2013, 08:13 PM | #4 |
Re: Suspension sag
As far as I know it's spindles and drop springs. But if I take out the rubber won't that make the wheel rub more?
06-24-2013, 08:26 PM | #5 |
Re: Suspension sag
Sure.
Front wheel/tire size has to work with your drop,... or you're going to have to raise it up. It's like a big puzzle. All the pieces have to work together. Otherwise you can ride on the bumpstops and have a crappy ride that all the "incorrectly dropped" truck owners,... complain about.
06-24-2013, 08:44 PM | #6 |
Re: Suspension sag
I'm running stock steelies
06-24-2013, 08:46 PM | #7 |
Re: Suspension sag
Then you will need a shorter tire, removed inner fenders, or taller coil springs.
06-24-2013, 08:50 PM | #8 |
Re: Suspension sag
So shorter tire and you suggest removing the bump stop all together? I really don't want to raise the front. I like the stance it has
06-24-2013, 08:58 PM | #9 |
Re: Suspension sag
Shorter tire and remove the bump stop. You can always install a set of those stubby bump stops as well.
06-24-2013, 09:01 PM | #10 |
Re: Suspension sag
What profile tire do you guys suggest? Sorry don't mean to be such a noob Roget now ha ha
06-24-2013, 09:09 PM | #11 |
Re: Suspension sag
What size tire do you have now?
Your truck looks good!
06-24-2013, 09:12 PM | #12 |
Watch out for your cornhole !
Re: Suspension sag
Take me a picture of the back side of the spindles and I will tell you if they're dropped or not. I need to see the arm where the tie rod bolts to.
06-24-2013, 09:14 PM | #13 |
Re: Suspension sag
235/75/15. Thanks I love the truck but this rubbing is driving me nuts
06-24-2013, 09:18 PM | #14 |
Re: Suspension sag
I have a 215/70 on a 7" rim.
You can run a 205/75 on a 6" rim.
06-24-2013, 09:30 PM | #15 |
Re: Suspension sag
06-24-2013, 09:31 PM | #16 |
Re: Suspension sag
I run 215/75 on the front. Discount Tire has them cheap and they are whitewall if you want to match the rears. I got a pair out the door for 126 dollars.
06-24-2013, 09:31 PM | #17 |
Re: Suspension sag
Yes those are drop spindles.
Posted via Mobile Device Posted via Mobile Device |
06-24-2013, 09:33 PM | #18 |
Re: Suspension sag
That's a good looking truck. Are those the stubby bump stops? How much drop do you have in the back?
06-24-2013, 09:35 PM | #19 |
Re: Suspension sag
I guess my next question is. Why does only the passenger side do it?
06-24-2013, 09:37 PM | #20 |
Re: Suspension sag
You've probably got a set of crappy springs in there. One likely more crappy than the other.
Don't get beat down though. You've got expensive drop spindles. Worst case you buy new springs. They're much cheaper than spindles. Posted via Mobile Device |
06-24-2013, 09:54 PM | #21 |
Re: Suspension sag
So more than likely they drop spindles are 2.5" with 3" drop springs correct?
06-24-2013, 09:56 PM | #22 |
Re: Suspension sag
So more than likely the drop spindles are 2.5" with 3" drop springs correct?
06-25-2013, 07:34 AM | #23 |
Re: Suspension sag
Or drop spindles with cut stock springs,...
06-25-2013, 09:12 AM | #24 |
Re: Suspension sag
Looks like I have some investigating to do. I appreciate all the help guys!
lolife99 what springs and front end rebuild kit is that on the red c10 As far as brand? Posted via Mobile Device |
06-25-2013, 09:23 AM | #25 |
Re: Suspension sag
MOOG rebuild parts.
Summit Racing 3" drop springs. Rear has ECE 6" drop springs, rear shock relocators, and Super Track Bar. I also added 1.5" lowering blocks. Posted via Mobile Device
