Old 06-29-2003, 09:22 AM   #1
Randy70C-10
Randy70C-10's Avatar
Need Jet-Hot coated header info
I've seen this posted a hundred times, but can't use the search feature. Who sells a good pair of coated headers specifically for my truck? (small block chevy, TH350 tranny) Thanks!
Randy70C-10 is offline   Reply With Quote
Old 06-29-2003, 09:45 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Randy, I have Hooker Super Comps on the same combo as you that used to be coated along time ago. It wore off. I don't know the age though. The cheapest ceramic price I have seen are Flow tech made by Holley. $199 at Autozone. Dynomax are about $225 at Jegs. Hedman also fit good I believe. Chevelle shorties by hedman if you are lowering seem to be popular. Let us know what you get!......Jim
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-29-2003, 09:59 AM   #3
Low69CST
I have headmans for my truck and I love them. Priced good and I've seen them on several trucks at shows and no discoloring. They are full lengths and are slightly noticable under the truck, but not bad.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-29-2003, 10:55 AM   #4
cdowns
cdowns's Avatar
i've got hedmans the fit is real nice no problems with the coating but they just suck with a lowered truck
Old 06-29-2003, 11:26 AM   #5
Randy70C-10
Cool, thanks guys! I would like to go with a full-length header, truck is lowered 3 inches in the front, also lowering 4 in the rear. would the hedmans be a problem?
Ah, just noticed that your is 2/3 lowered, do yours hit?
Old 06-29-2003, 12:28 PM   #6
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Anyone have those Dynomax Ceramic coated headers? Small block and T350. How do they fit? Any tweeking needed??
thanks
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 06-29-2003, 12:37 PM   #7
cdowns
cdowns's Avatar
yes the hedmans will b a problem i have a 21/2/4 drop and can't pull in/out of lots of driveways or off the shoulder of a road forget about speedbumps and if you pit potholes all i can say is good luck!! the whole collector section of the header is below the frame rail
Old 06-30-2003, 08:21 AM   #8
Randy70C-10
I'm now thinking about getting the Flow Tech's by Holley. Has anyone here used them?
Old 06-30-2003, 11:39 AM   #9
rigo
Flake Daddy
rigo's Avatar
Randy, I've got the regular, un-coated flowtech headers....great fit...slipped right in.......they do hang below the frame about 2"....but other then that...i'd buy another set........i wish i'd had the money for the coated ones....i just like the look and the protection factor of those....
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension
1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension
1998 Range Rover
1960 El Camino....in the works.....
rigo is offline   Reply With Quote
Old 06-30-2003, 11:44 AM   #10
cochino12
It followed me home?
cochino12's Avatar
I am running a pair of sanderson headers they are shorties though dont know if thats what you want
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-30-2003, 12:19 PM   #11
Randy70C-10
Thanks guys, I went and ordered a pair of ceramic coated Flow-Techs. I'll get pics once installed.
