Old 06-25-2013, 09:55 AM   #1
nele22
Need tire size help. See inside
All,
I am installing a DJM 5/5 on my 69 short bed fleet this weekend. I currently have 255/70/15 on the truck. I am sure those will be too tall.
I have a set of 15x8 with 3.75 back spacing (-19mm offset) that I am installing as well.
What size tires should I buy? Same size front and rear? I need to get these picked up today or tomorrow so the help is appreciated.
nele22 is offline   Reply With Quote
Old 06-25-2013, 10:12 AM   #2
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
Re: Need tire size help. See inside
It all depends on how you want the truck to set when you are done. I am a guy that likes some hot rod style rake. My suggestion is 275/60/15's and 255/60/15's. As you can tell I also like as wide a tire as I can get too. Those size tires will fit your 8" wheels and wear properly .
That's my .02 worth .
I dont think your 255/70/15's would be too tall for the back , but probably would be for the front. I also really think that size tire looks stretched out on an 8" rim.
ksbrktracer is offline   Reply With Quote
