06-25-2013, 12:14 PM | #1 |
K2500 rear Dana 60 wheel cylinders
Lookin for part numbers (GM or other brand) for the rear wheel cylinders on my Dad's '72 GMC K2500 with Dana 60 rear axle.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-25-2013, 04:03 PM | #2 |
Re: K2500 rear Dana 60 wheel cylinders
GM #5462163 RH, 5462164 LH are what I am coming up with for old part numbers. They should be the same as the cylinders I found for Mister-B's truck at NAPA. You might try checking there online first to make sure they are correct for your application.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-25-2013, 10:20 PM | #3 |
The only difference in wheel cylinders is coil or leaf. C-model leaf is the same as K-model
06-25-2013, 11:48 PM | #4 |
I you want to try a Raybestos part number..Left WC37040, and right WC37039.
06-26-2013, 01:11 AM | #5 |
Member #1049
Dana 60 ¾ ton wheel cylinders:
"coil spring" Raybestos:#WC37040 (L) Raybestos: #WC37039 (R) “Leaf Spring” Raybestos: #WC34474 (L) Raybestos” #WC34475 (R) |
06-26-2013, 12:21 PM | #6 |
Thanks guys I appreciate it! Just wanted to be sure in case they were different between the Eaton rear and Dana 60.
