![]() Join Date: Feb 2001
Dana 60 - Is it a Posi or not?
I just picked up a Dana 60 at a junkyard out of a 1970 GMC 3/4 ton. It listed "maximum traction rear axle" on the SPID. This is Chevy's version of "power lock rear axle". How can you visibly tell if it is a posi? I took the inspection plate off and couldn't really tell. It had some blocks between the spider gears but no clutches. Thanks.
JQ Posted via Mobile Device
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
Moderator
![]() Join Date: May 2007
Re: Dana 60 - Is it a Posi or not?
If both axles turn in the same direction it is a posi.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Cluster King
![]() Join Date: Nov 2012
Can you post some photos?
Here's a picture...
Cluster King
That looks like a powerlock and it should have clutches inside. They are hard to see but they are there.
![]() Join Date: Mar 2003
Definitely a power-loc. One of the achilles heel of the unit is the long bolts on the right hand side. Pull the cap off and check the bolts for being tight. I think torque is 50 lbs and the cap is (I think) 65-70
Thanks for the help guys! Well, I just did a lot of work for nothing. I've got a '69 GMC Custom Camper that I put the posi rear in. Pretty nicely optioned truck with 396, TH400, A/C, aux. battery, etc... but no posi on the SPID. The picture above is actually the rear I just pulled out of the '69. The '70 rear I installed looked identical to this one so I wasn't sure if they were both open or both Power Lock. On the bright side, I've got a desirable axle for sale!!
Joshua
