Old 06-25-2013, 02:18 PM   #1
MikeN
MikeN's Avatar
64 C10 Front Disc Brakes
Does anyone know of a front disc conversion that uses my stock drum brake spindles? Just got done totally rebuilding my front suspension, and hate to pop the spindles back off the ball joints, re-align front end, etc.
MikeN is offline   Reply With Quote
Old 06-25-2013, 03:40 PM   #2
MikeN
MikeN's Avatar
Re: 64 C10 Front Disc Brakes
Now that I think about it, I guess there's nowhere on a drum brake spindle to bolt the caliper bracket, unless it used the same holes as the steering arm somehow.
Old 06-25-2013, 04:29 PM   #3
tincan1966
tincan1966's Avatar
MBM Power Brakes makes a kit, as well as several others. The drawback(to some people) is they normally only allow for 11" rotors and 5 X 4 3/4" bolt pattern(they use Chevelle rotors and calipers.
tincan1966 is offline   Reply With Quote
Old 06-25-2013, 05:32 PM   #4
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I can get you a stock heighth or a lowering disc brake spindle and 6-lug rotors that will fit your balljoints etc ....made for 63-70 by Mcgaughys
ksbrktracer is offline   Reply With Quote
Old 06-25-2013, 05:53 PM   #5
LDO
LDO's Avatar
CPP makes a kit and I believe so does POL. I actually had the cpp kit for sale a while back but it sold already.
LDO is offline   Reply With Quote
