06-25-2013, 03:15 PM | #1 |
Dash Problem
So I got a new gauge cluster and as I took my old cluster out I broke some of the screw holes in the dash. Any ideas how to fix this?
06-25-2013, 05:05 PM | #2 |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Re: Dash Problem
Use this stuff by the case at work, (public Transit) it holds up well over the years
http://www.devcon.com/products/produ...m?familyID=175 Last edited by johnnyclack; 06-25-2013 at 05:05 PM. Reason: incomplete message |
06-25-2013, 05:30 PM | #3 |
Re: Dash Problem
We use 4 minute epoxy at jet. Same thing though
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
06-26-2013, 09:38 AM | #4 |
Re: Dash Problem
What exactly do I do with the epoxy?
06-26-2013, 10:00 AM | #5 |
Re: Dash Problem
(this is just one way, there are others)
Repair the broken pieces, filling in the screw holes as you go. Return the next day & carefully drill undersize holes(shallow depth just to help the screws get started), if the originals are not self tapping screws then pick up some (same size / length) at your local parts store. Carefully install them, remember it’s only holding minimum torque. Tip: By waiting until the next day for the epoxy to cure, the screws should remain removable.... |
06-26-2013, 10:09 AM | #6 |
Re: Dash Problem
Okay thanks man! This is awesome help. My new cluster will finally stop feelin like a red headed step child laying around the shop.
06-26-2013, 10:14 AM | #7 |
Re: Dash Problem
You may have to layer up the epoxy to get the hole deth you (might) need
