Speedwarning/tach dash
Paypal is preferred with the buyer covering fees, or postal money order, but paypal is my preferred method. Shipping is CONUS, not Alaska or Hawaii or anywhere else over seas, unless buyer covers additional shipping charges. Posted prices are shipped plain old USPS.
speed warning/tach dash. I believe this was assembled with original pieces, not an original factory assembled dash, replacement bezel and maybe lens. was in running truck and tach worked occasionally but usually not, and speed warning never buzzed, although there is a harness and buzzer and everything seems to be there and sw needle turns freely. other gauges seemed to work properly. what is pictured is what is included. $400 or offer NEW PRICE $300 plus shipping and fees, so $335 shipped!!! would trade for 72 extreme bend tow hooks if someone is interested in that Last edited by BurnoutNova; 07-25-2013 at 01:32 PM. Reason: price drop |
Re: Speedwarning/tach dash
Here are more pics
VA72C10
![]() Join Date: Mar 2008
Just an fyi for you and your sellers...it's missing the grounding pin that's on a correct speedwarning tin where the red wire goes through....that may be the reason why there was no buzzing. Was the red wire hooked up anywhere when you removed it?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: Mar 2012
i will offer you 200.00 for it, that pin is a must have<<
Moderator
![]() Join Date: May 2007
The pin is not a "must have". All it does is make a connection between the wire on the gauge, and the buzzer harness. It looks like someone just ran the speedo wire through the hole to connect it to the harness. A lot of setups are done this way and they work just fine. It is not seen when the gauge cluster is mounted.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#7 | |
![]() Join Date: Apr 2010
67-72=-5
![]() Join Date: Jun 2007
$300 plus shipping and fees?
1972 Cheyenne super swb 4x4 "QUEEN" 1996 Dodge ram diesel.... 4x4 "HORSE" |
Moderator
An easy way to test the buzzer is to connect it directly to the positive and negative terminals of a car battery. Pictured here is how I test a buzzer, using a factory harness. I added a couple pigtails, the blue spade terminal ends shown in the upper left are touched to the positive and negative terminals of a car battery...it doesn't matter which, if the buzzer is good it will buzz either way. My guess is it is "dead" as most of them are.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
leddzepp>>you can make anything work, what i meant is its a must have if i was to buy this for 400.00. BurnoutNova, no disrespect, someone will grab this im sure.
#11 | |
#13 |
Bump
#14 |
Bump
#15 |
Bumpity... I'm willing to hear some offers!
Posted via Mobile Device |
#16 |
#17 |
Bump who wants to make an offer
