Old 06-25-2013, 07:14 PM   #1
Jamminjohn
Pulling A/C?
I am going to be pulling a motor soon and wanted to what is the correct way
to remove the air conditioning?
I will be replacing the A/C pump with something new
Jamminjohn is offline   Reply With Quote
Old 06-25-2013, 07:27 PM   #2
Lee H
Lee H's Avatar
Re: Pulling A/C?
If your system still has a charge you should visit an AC shop and have the refrigerant recycled
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-25-2013, 07:29 PM   #3
Jamminjohn
Re: Pulling A/C?
It came with the belt disconnected, So I am going to guess that it doesn't work.
But I am not 100%
Old 06-25-2013, 07:41 PM   #4
TonyJohnson
TonyJohnson's Avatar
Re: Pulling A/C?
Sometimes it's possible to remove the compressor and leave the hoses connected. Depends on how yours is hooked up. If you can put a fender cover under it and use a bungie to keep it out of the way, you won't necessarily have to lose the charge. If you do need to remove the hoses, you could hook a recharge gauge to it and see if it's still under pressure.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 06-26-2013, 07:22 AM   #5
MARKDTN
Re: Pulling A/C?
That is the correct and legal way.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
