06-25-2013, 09:38 PM | #1 |
Grinding noise in bellhousing ):
in my bellhousing of my saginaw 3speed when i let the clutch out it makes this grinding/rubbing noise/ the truck will jerk if you try to move it. i have the transmission yet just not the bellhousing because those bolts are soo tight and hard to get to but i will get that off tmw im just curious of whats going on I MISS MY TRUCK!
77 c10 (went from a inline 6 to 350) (converted to 3 speed in the floor) 350: mild cam, holley 600cfm 4bbl, summit stage 1 intake, accel billet distributer, flowtech headers, 2 1/4" exhaust with glasspacks, powermaster 160a alternator. |
06-25-2013, 09:57 PM | #2 |
Re: Grinding noise in bellhousing ):
Possible your clutch is just that worn that the rivets are grinding the flywheel.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
06-25-2013, 11:05 PM | #3 |
sorry but i forgot to add i just put a clutch in when i did the engine swap
06-26-2013, 02:59 AM | #4 |
Did you do a new pilot bushing as well? What about the pressure plate? What all is new And used underneath?
06-26-2013, 09:45 AM | #5 |
Did you put your disc in backwards?
06-26-2013, 02:34 PM | #6 |
i did not put in a new pilot bushing but my clutch is installed correctly ive been driving the truck everyday until now
06-26-2013, 02:38 PM | #7 |
Could possibly be clutch chatter if the pilot is worn. If you replace it find an oilite type bushing
06-26-2013, 02:42 PM | #8 |
i also forgot to add with the clutch out at idle you can look at the clutch fork and it vibrates very bad and so does the clutch pedal
06-26-2013, 06:49 PM | #9 |
Here's a couple of thoughts. First about the pilot bushing. You can buy an actual bearing for this application. GM used them in the early diesel trucks. Second, with your noise problem. Two thoughts, first is your throwout bearing may have crapped out. Second would be that some of the clutch cover bolts may be coming loose.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
06-26-2013, 07:32 PM | #10 |
the throwout bearing seemed fine but when i took the transmision out the throwout bearing just kind of fell out..
06-26-2013, 08:24 PM | #11 |
The throw out bearing should stay on the clutch fork unless it pulled out when you pulled the trans. You have the fork clips in the inside if the groove of the throw out bearing?
06-26-2013, 08:38 PM | #12 | |
06-27-2013, 02:16 PM | #13 |
i had a "mechanic" install the the throwout bearing i really dont know how he had it
06-27-2013, 04:18 PM | #14 |
Ok well take it all apart and we can guide you in getting her done and back on the road. Worst we can do is fix it right?
06-27-2013, 05:01 PM | #15 |
I agree with your thoughts on a bushing. I hadn't heard of the bearings giving problems though. Anyway lets get this truck fixed!!!!
06-27-2013, 10:53 PM | #16 |
well guys a bit of and update but first of all i wanted to say thanks, but i got the bellhousing off and there was metal shavings in it! it was getting dark so i quit for the night but i will be back at it soon!
06-28-2013, 12:14 AM | #17 | |
06-30-2013, 01:18 PM | #18 |
Any updates???
07-14-2013, 11:40 PM | #19 |
well guys, i started the truck without the traqnsmission hooked up and it sounded beautiful, took the pan off the transmission and found chunks of metal and steel balls. lol. good thing i found 2 700r4s for 100$ sorry it took me so long to update
07-14-2013, 11:42 PM | #20 |
So an input bearing or throwout bearing failure I presume?
07-14-2013, 11:59 PM | #21 |
throwout bearing was fine, so i guess it was the input. i dont know much about transmissions this was my first truck and my first engine swap/rebuild and so on, but heres the pieces we found
07-15-2013, 12:33 AM | #22 |
Yup internal bearing. Saginaw trans right? Those aren't to hard to find
07-15-2013, 12:38 AM | #23 |
yeah, its a saginaw. this is the 2nd one that has been destroyed in my truck. Having a heavy foot doesnt help though
07-15-2013, 01:00 AM | #24 |
Yup late saginaws are pretty weak. Time to upgrade.
07-15-2013, 01:02 AM | #25 |
yeah, it was fine when i had my 250l6 in there and now with a mildly built 350 it didnt even last 2 weeks
