Old 06-25-2013, 10:28 PM   #1
nele22
Fuel sending unit disconnect. Need some help here
All,
I am trying to replace the sending unit in my in cab tank. The truck is a 69. I cannot seem to loosen the fittings on the gas line. Anything I am doing wrong. How do I get the damn unit out if I cannot but the fuel line free from the unit itself?
nele22 is offline   Reply With Quote
Old 06-25-2013, 11:19 PM   #2
nele22
Re: Fuel sending unit disconnect. Need some help here
Finally broke lose and wouldnt you know it... LMC send the 4 barrel 5/8" sending unit and I need the 5/16". Darn the luck.
Old 06-26-2013, 12:19 AM   #3
nele22
Well problem solved. Decided to switch the new float with the old one and re install the old unit. Viola.... Working fuel gauge. I feel like I am talking to myself.
Old 06-26-2013, 12:57 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Fuel sending unit disconnect. Need some help here
Good job. Good thinking on your part also and saved the return fee on the wrong part.
Yea sometimes it just takes a while to get any replies.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-26-2013, 03:40 PM   #5
nele22
I am sure it did not help that it was late. Sometimes I post just to talk myself through a problem online!
