Old 06-25-2013, 11:56 PM   #1
JellyBeanDriver
86' Dually - tire rotation between front and back?
Our 86' Dually, the front right has bad outside edge wear, not down to the cords, but nearly smooth. Rest of tire is good, as are all the other tires.
Can the front tires rotate with the rear? Are all the rims the same just with the rear the outer tire is flipped inside-out?
Lastly if so, what is the rotation pattern?
Going to take it in for an alignment at some point - not sure what would do that kind of wear this quick and not also affect the left tire.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 06-26-2013, 08:14 AM   #2
Desert1957
Desert1957's Avatar
Re: 86' Dually - tire rotation between front and back?
Name:  dually tire rotation.jpg
Is this what your looking for?
Desert
Desert1957 is offline   Reply With Quote
Old 06-26-2013, 10:33 PM   #3
JellyBeanDriver
Thanks. I did see that later when googling.
Suppose I'll give it a try this weekend and see if all the rims are the same.
Old 06-27-2013, 10:34 AM   #4
Desert1957
Desert1957's Avatar
I just reread your thread, Yes all Dually wheels on the same truck SHOULD be the same.
Desert
Old 07-01-2013, 01:36 AM   #5
JellyBeanDriver
Did the rotation today. Ended up being no big deal.
