Old 06-26-2013, 09:27 AM   #1
focusedontheprize
focusedontheprize's Avatar
Electric fan wiring issue
In my '49 I am currently running a 2 speed older Taurus/Sable fan. I am also running a 21 circuit EZ Wiring harness throughout the truck also. The truck is outfitted with LED turn signals and tail lights.
There really isn't much pulling for power on the harness I believe (my uncle is doing the wiring on the truck). Everything is hooked up at the moment except the fan and it seems every time he tries to run the fan he blows a fuse.
How did all of you guys running electric fans hook them up?
focusedontheprize is offline   Reply With Quote
Old 06-26-2013, 09:40 AM   #2
mknittle
mknittle's Avatar
Re: Electric fan wiring issue
Some of the higher amperage fans run a relay.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 06-26-2013, 09:50 AM   #3
mknittle
mknittle's Avatar
I found this on a Taurus forum
Mark
My GMC build.
Old 06-26-2013, 09:51 AM   #4
focusedontheprize
Thanks. Yeah at the moment he has a relay in the loop. He said last night he tested it and when the relay is in the circuit (think that is the proper term) the fan does not work, however when he bypasses the relay the fan works fine.
Also thanks for the diagram, I will send that over to him.
Old 06-26-2013, 10:03 AM   #5
mknittle
mknittle's Avatar
You're welcome. sometimes you find god info in the strangest places
Mark
My GMC build.
Old 06-26-2013, 10:32 AM   #6
Rufton
I've experienced relay failure; the relay contact developed a white crust. Now I run redundant relays, redundant switches and redundant fuses. Occasionally, I verify both high current circuits are functioning; which reminds me I need to check em.
You probably know a relay can allow a low current circuit to trigger a separate high current fan circuit. I do have fan rated fuses in the high current circuits.
Rufton is offline   Reply With Quote
Old 06-26-2013, 02:20 PM   #7
focusedontheprize
Yep. Relay failure it was . Ah Pepboys .
Old 06-26-2013, 07:20 PM   #8
Rufton
Did you dissect it outta curiosity?
Old 06-26-2013, 09:48 PM   #9
mknittle
mknittle's Avatar
I see I am not the only one that does that
Mark
My GMC build.
Old 06-27-2013, 05:13 AM   #10
OKGMC4
OKGMC4's Avatar
The two speed ford fans really need a hefty relay. They cool great but pull high amps, and that can burn up a small relay quick. If it happens again try a heavier relay.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-27-2013, 08:02 AM   #11
focusedontheprize
Yeah, I was reading about that before. I was talking to my uncle who does electrical engineering and he used a heavy relay on it. He texted me yesterday during lunch time and goes "I am spending my lunch time on this truck" and this man likes a good lunch! Knew it was bothering him.
I told him I wanted to look at it when I was home next week so I will have to see what it is.
Old 06-27-2013, 01:47 PM   #12
Russell Ashley
Russell Ashley's Avatar
Rufton, are you powering your fan with two circuits simultaneously or is one a backup that is not used until you switch it on?
Russell Ashley is offline   Reply With Quote
Old 06-27-2013, 05:02 PM   #13
Rufton
Two completely independent circuits. Relays can run simultaneously or independently. Both circuits are automatic and live. One of those overkill kinda things.
