Custom 3spd Shifter bushings
Hey guys,
I think I've made an improvement to the 3 on the tree shifter in my chevy... I searched for replacement bushings, and yes I do realize there are a few places you can get them, but I decided to step things up a notch. I took measurements for top and bottom bushings, and did up drawings for them. Sent the drawings to a buddy who works at a metal fab shop, and they turned them on the lathe for me out of SAE 660 bronze. Here's the finished product! ![]() And with the two parts assembled: ![]() Got them home and installed them...they fit great! I sized them for an RC5 medium running fit, and it seems to have done the trick. The truck shifts with way more precision now. ![]() ![]() ![]() So for anyone that keeps the 3ott shifter....and I know there's a few of us...here's an option to consider when your bushings wear out. Has anyone else fabbed bushings for these?
![]() Matt. 16:26 '08 Sierra Reg Cab, shortbox - daily driver '69 C10 LWB, 250, 3OTT - summer driver '98 STi Type-R (JDM) <SOLD> '97 WRX STi (JDM) <SOLD> |
Re: Custom 3spd Shifter bushings
Nice job and I bet it works way better than before.
I'll take a set if you plan on fabbing some more! |
Looks good! Bet they work great. Not for these trucks, but I have fabricated similar brass bushings on the lathe for the clutch and shift linkage in my '69 GTO.
Even in perfect working order I find column shifters to be cumbersome - lots of weight to move around. The three on the tree in my C-10 got yanked in favor of the Hurst floor conversion kit. Best thing I ever did to the truck. ![]()
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
Thanks guys, yes I would never argue that there is any advantage at all to shifting on the column...but there are three reasons I'm keeping it for now:
1. The far-away look in an uncle's or grandparent's eye as it brings back memories 2. The amazed/puzzled look on someone's face that has never seen it before 3. The great nostalgic feeling as I swing thru the gears. Plus I've just got the I6 250 in front of it...so the only thing quicker shifts would do for me is shave a few seconds off my 30 sec 1/4 mile.. ![]()
All valid reasons. No arguing the nostalgia factor!
![]() Think I'll pull the column shift rods off the wall again just for fun.
Great product. If you decide to mill out another set let us know!
88Ironduke |
![]() Join Date: Jan 2012
Agreed.
Awesome, I want some too...
![]() ![]() 71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
I would like a set also !
71 C-20 07 Magnum RT AWD |
Wow maybe I should do up some more hey? sounds like there would be some demand. Unfortunately the bronze stock is pretty pricey. Just the material alone cost around $50, (1" round bar) and I was fortunate to get the machining for free.
Its these sorts of little custom upgrades that makes building these trucks so much fun ![]()
Yeah, that sounds kind of spendy for 660 bronze. $50 for the whole bar or just what was used for the bushings?
Pricing: http://www.onlinemetals.com/merchant...=761&top_cat=0
Active Member
![]() Join Date: Jul 2007
Or,,, at least post the measurements you have for us brother truckers.
![]() Those look great on the truck. I made my own out of metal tubing and rubber hose many years ago. So far they've held up and work good but they're nothing to look at.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
#13 |
I was recently doing some adjustment on my 3OTT, (250 I6 as well) and though it really helped with shifting, I did notice how sloppy of a fit it was under the cab. I put together some miscellaneous things from the bench top to see if it would work (sorta), but I would definitely be interested in a set of properly fabricated ones. If you make 'em, we'll take 'em......
#14 |
If nothing else, post the measurements. That looks fantastic, all of us boys with the ol' sloppy 3OTT are jealous.
#15 | |
Nice work!
#16 |
How much do you think they would cost if you added your labor? I would be interested in having a set too.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#17 |
I also notice that one of those bolts is nice and new looking, did you just clean it up and paint it or is that a new bolt? If new, where did you find it at? Thanks.
#18 |
Where can you purchase these?
#19 |
I redesigned the shift bushings on my 78. These are the prototypes I made from mild 1018 steel. They are adjustable for wear. These two are currently installed on my truck and they work great. I'm currently working on a set made of 4140 chromoly (pre-hard) for greater wear resistance. The 78 doesn't use metal bushings on the column end, only at the transmission, hence the reason why there are only two.
The pic isn't that good, but it's all I have. |
#20 |
Here's a pic, comparing the factory bushing to my bushings.
#21 |
I would be interested in a set also . thanks , kenny .
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
#22 |
Wow I'm astounded at your guys feedback on these! Thanks for the interest! I don't intend to do another batch of these, but here are the drawings I provided to my machinist...provided for "reference" only.
![]() ![]() I hope these work for you guys, at least they save you the time of making your own drawings. Cheers, Colin
#23 | |
We can't archive those until they are completely signed off... ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#24 |
Haha, relax. As the originator I am taking the liberty of skipping all checks and approvals lol. In this case the bold red FOR INFORMATION stamp covers a multitude of sins.
